Question about Haier HTE18WAA Top Freezer Refrigerator
Freezer fan frosted again
Dear Sirs:
You were extremely helpful a week or two ago with diagnosing a haier fridge problem for me. I thoroughly defrosted and cleaned the unit before starting it up again. Unfortunately, the same problem has quickly reoccurred. I noticed the fridge warming again, saw that the freezer fan had stoped again, and pulled the freezer back off again. I was again able to start the fan by hand and it is moving at the moment. I also noted a great deal of frost build up on the rear coils and other components, much more so after just a week or two now than when I pulled the unit apart a couple weeks ago after four years of operation (the unit is currently set at its maximum temperature because the fridge has been warming again). I am trying to figure out whether I may have done something wrong in my servicing or whether there is still one or more problems elsewhere.
Of specific note this time around, I can say that with respect to the two "exhaust" vents in the top of the refrigerator, on one side my unit was equipped with a styrofoam insert with a 90 degree bend that directed the regrigerator exhaust directly over the drain pan in the rear of the freezer. On the other side there was no such insert. With much more frost this time around, it was easy to see that on the "insert" side, the frost was mostly limited to a section right where the insert exhausted. On the side with no insert, the frost was much more evident and thicker all the way up the coils and components on that side of the unit, and also accumlated some under the freezer floor, since that is where the exhaust hole ends without an insert similar to the other side.
Based on what I saw this morning, is it safe to assume that the unit is supposed to have one of these stytrofoam inserts on both sides when mine came with only one, and that this could potentially be contributing to or even causing the problem I have been having with the freezer fan frosting and stopping? If only one insert is standard and okay, is there anything else you can figure or suggest from the information I have given? Thank you again so much for your help and time.
    Sniper:
  • 65 Answers
It is not soposed to have two inserts one is the inlet air (controlled ) the other returns air to freezer . when fan has stopped check it for voltage if it has voltage replace the evaporator motor (fan).
Posted on Feb 16, 2008
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Fan housing has frost buildup and fan blade is hitting the ice. I removed the ice about 6 weeks ago and it's doing it again?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator Fan Noise
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 11, 2010 | Refrigerators
My fridge wont stay cold.
it is not frost free , there is no fan , this fridge for light office use , also make sure gasket is ok , good luck:)
Sep 12, 2009 | Haier (B000194UBA) Compact Refrigerator
Frost free combo unit fridge keeps getting warm
Hi: You have a bad defrost heater or defrost timer. I'm not familiar with the brand but the heater will be below the evaporator coils in the freezer ( in the back behind a panel.) When you do your defrost that your dad told you to do, it will work until it frosts up again. You are doing the work of the defrost heater. I hope this helps, Jeff
Jun 02, 2009 | Belling BE811 Bottom Freezer Refrigerator
The fridge compartment not getting any cold air.
Well for whatever reason the fridge compartment is now getting cold air again and its all working fine. Have no idea whats gone on with it but is working again hahaha. The only thing that we did was take the back off the freezer, where it houses the fan motor, the motor wasnt quite straight so I straightened it and now its working. Whether that was the problem to begin with I have no idea.
Apr 12, 2009 | Westinghouse Refrigerators
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Freezer cold, but Fridge only a little cool
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
Aug 28, 2008 | Haier HRF10 Top Freezer Refrigerator
Freezer okay, fridge warm
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Jan 30, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Haier HTE18WAA Top Freezer Refrigerator Logo
128 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
