FixYa.com
Tags:
Brother ML-500 Typewriter
Unable to set margins
posted by Laker1980 on Feb 06, 2008
The ML-500 will not allow me to clear and set margins. We are limited to the last 1/4 of the line, so we are unable to type full forms. I am new to this office and can not find the original book that came with the machine.
Comment by Laker1980, posted on Feb 06, 2008
Hi John,
Thanks for trying. It did not work, however. I believe the typewriter is finished. Now I must shop and present a recommendation for a new typewriter...
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
JohnGoodman
Rank:Wiz Wiz
Rating: 90%, 23 votes
To set the Left margin:
1) Move the carrier ro the place you want to set the left margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current left margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[L MAR(4)]. The left margin is now set.
To set the Right margin:
1) Move the carrier ro the place you want to set the right margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current right margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[R MAR(5)]. The right margin is now set.
That is directly out of the manual. I will upload the manual to FixYa, and you will be able to view it from the ML-500 Typewriter's product page: http://www.fixya.com/support/p131634-brother_ml_500_typewriter
-John
Rating Locked! (?) Laker1980 has rated this solution as Thanks for Trying
Solution #2
posted on Mar 15, 2008
Not Rated (0)
RadarRon
Rank:Guru Guru
Rating: 87%, 44 votes
You have to release the margins before you can set them.
[ALT]+[M REL] (#3 key)
You can get a copy of your manual here.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ML500_EN_218.PDF
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Typewriters problems?
Typewriters
Ribbon issue
The ribbon will not advance on... Answer This...
Typewriters
Olivetti Lettera 32 - carriage...
I've just bought a Lettera 32,... Answer This...
Typewriters
key
How i can get the product key... Answer This...
Character print
I have a character,... Answer This...
COMO LE PONGO MARGENES A LA...
no se como poner la margen en... Answer This...
Repair Service
Find Typewriter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
