Question about Nokia 9300 Smartphone
Not able to take print out
Actully i would like to take printout of my call histroy. any budy can help me how to take a printout
  • santoshkm Feb 06, 2008
    how to install extra external devices with this handset
    like printer, scanner , or connect with pc for internet browsing etc
    is it required to write a script or tools is available in the market
    how to do programming with 9300
    Scholar:
  • 174 Answers
Have you tried calling Metro PCS and getting them to mail you a copy of your call log? They might charge you a fee for it, but they can do it. They are by law forced to retain call logs.
If this is truly a "life or death" situation, the police can subpoena them for it.
Posted on Jun 09, 2009
What is the cause of characterized printout. When I printout a test page, it just prints all sort of digits and numerals in no chronological order. What is the cause, is it the motherboard??
A print test page does just that the printer will print every character that is in its memory, together with lines and if it has colours will also use the different colours
Oct 06, 2015 | Office Equipment & Supplies
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
The Lexmark x5495 printer is not printing correctly. The printout is not aligned properly. The printout is crooked. How can you solve this problem?
Try to re-seat your cartridges and make sure they are properly inserted in the cartridge carrier.
If that doesn't help, please do the Align Cartridges function on your printer. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Align Cartridges. You printer will then print a test page that will help align the cartridges.
After the page is printed, try to print a document again to verify that the problem is fixed. Thanks.
Feb 25, 2012 | Lexmark X5495 Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
No printout result for my epson r230 stylus
no print out?, you must replace your main board, the IC in printing may be damage it should be replace.
Jan 26, 2010 | Epson STYLUS R230 InkJet Photo Printer
Hp designjet 500 (42'')
1. remove your catridge
2. remove or change the foam which is located
at the bottom of catridge head
3. hope this will help you to solve your problem
thanks
Jun 16, 2009 | Office Equipment & Supplies
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Estudio 352 is not help to take out printout from computer
Hello sir; When you make copy does it print? if there also no print out you better check the corona wire (charge & discharge) it should take care of you, if still don't work let me know.
Dec 30, 2008 | Toshiba Estudio 200L Copier
HP5550 printer; printing VERY slowly
check in which mode u had selected the printout.
1)best mode (the printout will be very slow)
2)normal mode(the printout will be fast)
3)draft mode(the ptintout will be very fast)
so check in your printer properties on which mode u r printing.
thanks.
Oct 13, 2008 | HP Office Equipment & Supplies
MFC240C - all printouts in green colour
green is a combination of Yellow and Cyan, it is possible that you are missing magenta, depends on the file you are trying to print, if you can print one of each color this time print only magenta it would be helpful to isolate w/c is w/c from there you can find out what is the problem
hope this helps
Aug 08, 2008 | Brother Multi-Function Center MFC-240C...
Nokia 9300 Smartphone Logo
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
