Question about Belkin (F5D5231-4) Router
SETTING UP SECURITY ON A BELKIN F5D7231-4 ROUTER
HI
Can anyone help a bit of a computer novice to set up above router as a secured network. The manual seems to be of limited help
  • 363 Answers
I would imagine your router is already set up for optimum security by default.
As long as you are having no problems then there may be no need to change any settings.
If you need to change any settings, for example opening a port for p2p filesharing then you can open the router menu in an internet explorer window by typing its IP address in the IE address box.
Routers normally ignore all incoming connection attempts but allow all outgoing communications and the responses that those communications request. The only reason you might want to change this is to allow outsiders to access the files on the computers in your secured network.
If you require more specific help then please ask!
Posted on Feb 06, 2008
Reset Belkin F8T030?
manual is here: http://cache-www.belkin.com/support/dl/f8t030_manual.pdf
but it seems like you can't reset it with a button or some other procedure
try to connect it to your network and search for it in command prompt by typing arp -a -> will show you list of all IP's on your network
Mar 12, 2012 | Belkin (F8T030) (BKNF8T030) Wireless...
I reset my Belkin Wireless Pre-N Router F5D8230 to the factory setting. Now I would like to put a password in to keep the wireless secure in my home. How do I do it?
With a Belkin wireless router you can connect computers to the same Internet connection without having to run cables between all of them. If you don't want any stranger with a laptop that is within the range of your wireless router to be able to access your network you will first need to enable the router's security settings.
1.Power on any of the computers that are currently connected to a network through your Belkin wireless router. Click on the "Start" button and then open the Control Panel.
2. Scroll down through the Control Panel options and double-click the "Devices" icon. Right-click on the entry for your Belkin wireless router and click on "Update Driver." Wait for the latest software driver to finish downloading and then close the Devices window.
3. Open your web browser by clicking on its corresponding desktop icon. Click on the address bar at the top of the web browser's window and type in the string of numbers and dots "192.168.2.1" Press the Enter key to bring up the router's access page. Click on the "Login" button.
4. Leave the password text box blank and then click on the "Submit" button to access the settings menu. Click on the tab at the top of the screen labeled as "Wireless."
5. Find the "Security" link at the center of the page and click on it. Click on the "Security Mode" drop-down menu box and then change the security mode to whichever setting you want. Choose the "128 bit WEP" option from the drop-down menu if you want to enable security encryption on your wireless network.
6. Click on the "Generate" button at the bottom of the screen to generate the encryption key and then type in a password you want to use in the "Passphrase" text box. Leave the box empty if you want anyone within range to be able to access your wireless router. Click on the "Apply Changes" button to save the changes.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Belkin Wireless Pre-N (F5D8230-4) Router...
Just hooked up the router to my pc and put in the install disc that came with it, the Belkin program won't open on my computer and the laptop I'm using shows it as an available wireless connection put...
Welcome to Fixya. If you want to connect to the Belkin Router Wirelessly and it is asking you for a Security Key, all you need to do is to access the router settings page and look for the Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
Thanks for using Fixya.
Mar 04, 2011 | Belkin Basic Wireless Router
I have wireless belkin 54 g how to setting security password cause all people can use my wireless thanks
Hi robidublin20,
If you want set a Security Code or Network Key to your network so that other people can't connect to your router you need to access your router.To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can set the security type of your router to WPA or WEP to make it secure. Under that you can set the Security Code or Network Key. Personalize it so that that you can easily remember it.
Don't forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Belkin F5D7234-4 Router
How do i reset my wps orange light stays on no internet
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 23, 2010 | Belkin (F5D7231-4) Wireless Router
Having problems connecting a lap top computer to the internet.
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
May 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I security enable my Belkin router?
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings.
Please write down the key – You will need it later to configure your wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Jan 01, 2009 | Belkin (F5D6230-3) Wireless Router
Unsecured net work
Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
/regards
Teis
Was this solution helpful? Show your Appreciation by rating it:
Nov 30, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231-4) Router Logo
77 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
