Question about Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Light began flashing after a paper jam. Removed paper jam. Paper tray has plenty of paper. Paper LED continues flashing.
nonnomack@epix.net
Thank you
  • 3 more comments
  • gfmiyahara Feb 11, 2008
    Also tried manual feed, no solution
  • Anonymous Feb 17, 2008
    same
  • gezish Feb 20, 2008
  • Anonymous Mar 20, 2009
    red light flashing..plenty of paper...prior to that toner flashing now no light for toner..
  • vmiller06 May 11, 2009
    paper keeps getting stuck. how do you clean the drum.
Clean the drum cartridge
Posted on Feb 19, 2008
Try send one paper manually, then it will pick up paper from the try automatically.
Posted on Feb 07, 2008
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Why does my 2040 Paper light (Red) keep flashing even though the paper tray is full and there is no paper jam?
There are several possibilities with too many to type here so, here is a link to the Brother troubleshooting page that gives several causes for the flashing red light. When you get to the page, scroll down until you see the "lashing "paper" light.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11
Hope this helps.
Aug 09, 2010 | Brother HL-2040 Laser Printer
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
Paper light keeps flashing. no paper jam and there is paper in printer. what else could it be?
Here are the led codes. Have you tried pressing the go button, and holding it down for a few seconds to reset the memory. Then press it again and see if the paper light is out.
Check also to make sure the paper setting in tray 1 is not set to undefined, but specifies your paper size. (Printer properties>Tray settings)
Then pull the tray all the way out, and look above where the paper sits for a little lever that hangs down to sense the paper. Make sure it's moving freely and not broken. Also check that there's no paper jammed in the back of the printer somewhere....
Jul 30, 2009 | Brother HL-2040 Laser Printer
Red Priner LED Wont stop flashing
it is problem paper jum.please chack it then solve your problem
Jul 24, 2009 | Brother HL-2040 Laser Printer
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
Same problem - Paper LED light is flashing, but no paper jam
try on pressing start buttom for 1 min to reset the machine.
it should be working fine after that.
Jun 15, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
1,647 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
