Question about Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Hey,
When I turn on my PSP and it goes into the main menu and the screen starts to flicker and when I navigate around it goes really slow. When I load into a UMD game it play fine though (from a UMD disk or off the memory card), it plays at a normal pace and the screen doesn't flicker at all. I have recently had my PSP moded and thought this might be an issue. Although for a week after the mod the PSP worked fine even loading games off of my memory stick. The PSP is a slim and only a month old, now that it is moded I think I am also screwed for my warranty. Can anyone give me some advice?
  • 11 more comments
  • jaibie24 Feb 21, 2008
    hi! i have the same problem. ive taken out the memory stick and tried to use it. for a few seconds it is fine but starts to flicker after and runs very slow on the main menu and when opening videos games etc....anyone pls help. i used to have 3.80 m33-5 and updated it recently to 3.90 m33
  • spongeboob Mar 08, 2008
    precisely the same problem , recently upgraded to version 5.71 tried the usual steps, such as rebbooting and systems restore under settings etc.
  • Anonymous Mar 31, 2008
    mine is doing the same thing but it's been a couple of weeks and it keeps doing that
  • ututin May 01, 2008
    my psp get so slow when i open it!
  • maniacrebel Jul 11, 2008
    The exact same problem....Mine's the old version and the screen flickers but is very slow...now I dont know what to do!
  • am_kenneth Aug 03, 2008
    try this one.. press the video button for 2-4 seconds, the screen will go black then press it again so that the display will comes back
  • Anonymous Aug 23, 2008
    starts to flicker and when I navigate around it goes really slow. plsss help me what can i do?
  • ajinkyanamah Nov 03, 2008
    even my psp has same problem n i too crackd 1 mnth earlier !!!!
  • Anonymous Apr 29, 2009
    what is the video button
  • muqadam77 Apr 30, 2009
    thanx a lot "guest", you have done the job. I recommend others to follow "guest's" suggestion.
  • ShadowBehold May 11, 2010
    Oh wow ty so much Dizzy! and the same EXACT thing happened to me.... like with the moding and everything!!! =D
  • frozenchen May 11, 2010
    where can i find the cpu clock?
    under what setting?
    plzzzzZZZzzz...
    heLLLLLPppppPPPP.......
  • hacker Apr 30, 2013
    Uninstall the cfw and install it again
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Posted on Feb 22, 2008
  • 10 Answers
Turn it off and then when restarting it hold down the R button. This will put it into recovery mode then go down to CPU options and change the XMB Cpu speed back to default it probably was at 20 or something and that is not enough to run the psp properly hope this helps
Posted on Jul 30, 2009
    Problem Solver:
  • 12 Answers
Open psp in recovery mode select advanced option reset and flash that is all,manilal
Posted on Aug 08, 2009
You should have custom firmware enabler in your memory stick enter that and then go settings then cpu speed xmb change to default
Posted on May 12, 2010
Try this one.. press the video button for 2-4 seconds, the screen will go black then press it again so that the display will comes back
Posted on Aug 03, 2008
  • 3 Answers
Thats a hardware issue not firmware check display of your psp
Posted on Jun 09, 2008
  • 3 Answers
I had exactly the same issue (screen flickering at boot and very slow boot speed and all around slow navigation speed on the psp menu, but the games where playable).
This is how to solve it:
Shut down the psp entirely by pressing the power switch up for a few secs until its really off.Press the R button and kep it pressed while turning on the console.You are now in the recovery menu, go down to CPU options and change the XMB and CPU speed to Default/DefaultExit, reboot and enjoy your recovered PSP.
Posted on Mar 12, 2016
    New Friend:
Power down the psp complete by holding up the power button until switch is down,then hold the R trigger while turning on the psp for menu and set XMD to default [u may set it to 333 but still be the same as default]
Posted on May 21, 2015
In the home menu off the psp press select and then the cpu clock XMB must be set to default thats what i did
Posted on Mar 09, 2008
    Sergeant:
    Champion:
  • 322 Answers
Yes i try a new memory card? if not just take it back but don,t exsplain what you done and if they do i just lave it a lone
Posted on Feb 06, 2008
3 Suggested Answers
SOURCE: PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
lol you guys have to google once in your lives, go to your XMB and press select then you will see something with XMB clock speed. most likely your speed will be in the low values. just change the value to 222 mhz or higher and your problem will be fixed
Posted on Oct 11, 2008
Go to psp recovery menu and set the CPU speed in XMD to default, it should work
Posted on May 12, 2012
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
My LG Lcd tv takes a minute or so to turn on then sometimes the picture flickers and goes out. The tv is on but no picture or sound. When I try to use the menu button on the tv it doesn't work. Whe
The fact that you have no menu or onscreen display, leads me to believe that it is the main logic board. Either the processor ic or the voltages going to the main board are missing. Check to see if the main board is getting 5v and 3.3v to determine if it is your power supply not supplying the voltages or your main board.
Oct 26, 2011 | LG 42LC2D 42 in. LCD HDTV
My laptop screen flickers in and out, screen goes black
Hello there,
The reason the screen flickers is simply because the module of the laptop is faulty. The module is what connects the screen to the main board, it is like a flex for the screen. Once you can have it replaced, the screen will stop flickering.
All the best Elect_Comp
Sep 13, 2011 | Acer Computers & Internet
On the main menu my my psp screen keeps flickering and is really slow.
Hold select in the menu and check if the following are NOT in default: CPU Clock XMB and CPU Clock Game if they are not in default set them to default to return it to normal speed
May 17, 2009 | Sony PlayStation Portable (PSP) Console
TV Screen Flickers
IF YOU PRESS THE MENU BUTTON IS THE THE PICTURE STILL FLICKERING ON THE MENU BLOCK.? IF SO YOU HAVE A THERMAL ISSUE WITH EITHER THE MAIN TOTAL ASSY, LVDS CABLE OR THE PANEL.
Jan 23, 2009 | Televison & Video
Flicker and very slow
turn off your PSP ,then switch on again.. when the screen are in black condition "press R button" and change the CPU speed
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
9,169 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
