Question about Konka KDL32AT23U 32 in. LCD Television
Konka KK-Y296A Inverter Board
I have a KONKA 32" LCD that has a bad inverter board. Where can I find parts?
  • 1 more comment
  • Lexmike Feb 07, 2008
    Haven't even been able to locate maker after spending 2 days on the internet searching.
    Thanks
    Have been watching eBay for a couple of weeks. Nada.
  • Ralph Moonshower
    Ralph Moonshower Apr 01, 2012
    http://www.fixya.com/HTTPHandlers/mail_d...
    This solution fixed mine
    Ralph
    Master:
    Sergeant:
  • 440 Answers
Ya im looking all over for u also
Posted on Feb 07, 2008
    Master:
  • 788 Answers
My first thought is eBay, that's where I find the inverter board for laptops I repair.
My konka flat TV has a power supply but its black when its turn on, where is the problem?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 11, 2017 | Konka Televison & Video
Why My konka tv model KP21EK602A (5740) picture dark
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Jan 26, 2017 | Konka Televison & Video
Konka led TV, black screen, no back light. What's th problem? Please
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 24, 2016 | Konka Televison & Video
Black sreen
Check and replace its CCFL back-light lamps and back-light inverter board.
Jul 15, 2013 | Konka KDL32AT23U 32 in. LCD Television
Universal tv remote control code for konka KK-Y26IN
Hi, this Konka remote is not a universal remote and cannot be programmed to any devices. It only works with the original Konka TV. To purchase a new Konka remote for you Konka TV you can go to Replacement Remotes.
Oct 06, 2012 | Universal Remote Control Remote Control
Hi I have sound but no picture it Niko 32 " tvI checked evry pssibel thing that can cause this . Thanks KK
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 22, 2010 | Niko SV3206 32 in. LCD Television
The picture comes on then after a few minutes it goes black and the sound stays on
The tv have 1 or 2 long boards call the LCD inverter board are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 20, 2010 | Konka Televison & Video
It being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Jun 17, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Konka KDL32AT23U 32 in. LCD Television Logo
606 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
