Question about Philips Magnavox 42MF521D/37 Television
Magnavox 37MF337B/37 overscan only sometimes problem
I have my computer hooked up via DVI to HDMI to the TV. I have an overscan problem with this connection. The weird thing is sometimes it will overscan and sometimes it won't. What I have noticed is when it does overscan on the info screen of the TV it reports the signal as 1080p. But when it does not overscan the info screen reports the signal as 1920x1080/60hz. I want t know how to make a certain input in this case HDMI1 always see the signal as the 1920x1080/60hz so that I don't have this overscan problem. Can I get into the maintenance screen and change the setup to make this happen?
  • cubbienina May 11, 2010
    I have a 42mf437B/37 MODEL MAGNAVOX 42" HD TV. And I need a manuel for it.
  • 476 Answers
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Posted on Feb 12, 2008
Cannot get HDMI output to work to my flat screen when while using DVI to monitor
you must download the Driver correctly, the driver can not be installed or corrupted.. See your company supplier from PC and proceed to download. or you have instaled the driver is corrupted.
Uninstalled and installed again with new version, see if the play and plug the driver is o.k or corrupted proceed with the same technic before
God bless you
Sep 25, 2012 | ASUS Essentio CM5570AP003 PC Desktop
I want to know how to hook up my PC to this TV as a monitor. The manual says to use HDMI 1 port and the DVI port on PC. Do i need to get adapters to make such a connection
an hdmi cable will do then hook up to hdmi port 1 and on tv select that input and it should work. of course the hdmi cable has to be hooked up to hdmi input on computer
Jul 08, 2012 | Magnavox 32MF339B 32 in. TV
Popping in speakers then lines through picture sometimes no sound
Likely bad audio output circuit---it will usually be part of the main board in these sets----not likely to be a do it yourself repair.
Apr 29, 2012 | Toymax Magnavox 37MF337B 37 in. LCD TV
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Sometimes when I turn on my Magnavox 37MF337B tv it emits a very loud squeal and the picture/channel locks up. I cannot turn it off with the remote. I have to unplug it and try again. When it is on though...
you have some bad caps in the mainboard very common on this model the can shaped devices will have a puffed up top i would suggest you have a tech reaplce them they are hard to get out due to the large ground plain on the board you need a good hot iron
Nov 24, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
No Pc Audio on HDMI
bad hdmi cable common problem
Apr 27, 2009 | LG 37LG30 37 in. LCD HDTV
Protron 37" HDMI not producing sound
Check the volume control on the DVR box. This is sometimes turned down. Good Luck
Mar 29, 2007 | Protron PLTV-37 37 in. LCD Television
Philips Magnavox 42MF521D/37 Television Logo
875 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
