Question about Maytag MZD2768G Side by Side Refrigerator
Ice dispenser appearing to get stuck in the open
Ice dispenser (the portal where ice comes out) appearing to get stuck in the open mode (when getting ice from front door), making loud noise until it finally dispenses ice (at that time noise stops) and dispenser closes the portal where ice comes out. Note: While dispenser opens and is making this loud noise, ice does not come out. When the noise stops, the ice comes out and at that time the noise stops, portal closes normally when cup is removed from the dispenser button.
  • 4,070 Answers
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Posted on Jan 08, 2010
SOURCE:
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
Aug 12, 2012 | Frigidaire Refrigerators
MSD2456DE. I just replaced th flapper on the ice dispenser and everything was working fine. At lunch the nexd day we kept hearing a click every few minutes, by evening, water was driping and we...
No, the circuit board mounted inside the ice dispenser on the door has no control over the defrost mode. Furthermore, the problem you appear to be having is not with the defrost system, rather the compressor attempting to start, but failing. This could be caused by a bad compressor, or a bad compressor start kit failure. Again, neither of these could be caused by an issue with the control board for the ice/water dispenser.
Oct 26, 2010 | Maytag Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Ice dispenser is stuck in crush mode
the solinoid is most likely stuck down. however most of the time there is more ice in there than you realize
Feb 05, 2010 | Refrigerators
Have a SS #GSS22WGPEWWW Ice not coming out
Try taking ice pan with auger out hold door open and press light switch for the door in while someone presses dispense ice. I want to see if the motor is turning behind the auger ice tray. The door switch has an interlock and when door is closed the dispenser controls should be functional. When open this disables water and ice dispenser. waiting on your response, Sea Breeze
Jan 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker will only dispense crushed ice
You may have a broken solenoid inside the motor assembly.  The solenoid controls the arm for cubed or crushed ice.  The only way to tell is remove the ice dispenser motor assembly and look at the solenoid.  If the solenoid is broken, replace it and everything should be ok.
Aug 18, 2008 | LG LSC26905TT Side by Side Refrigerator
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Open Questions:
Maytag MZD2768G Side by Side Refrigerator Logo
351 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
