Ps3 sound setting for Acoustic Solutions tv
I cant get my ps3 sound to work.
it says the feq i need to pick and also i got the Acoustic Solutions tv. the background sound works fine its the people voices and when playing a game its usaly the voice of the people that dont work
can some one help me please!!! i allso have a hdmi cable and hooked it up with the tv but no voice[only the people]
  • Anonymous Apr 25, 2008
    same prob wid me??
  • keeps1117 Dec 05, 2008
    same problem the background music is fine but the (ingorund?) peoples speech, e.g during a cutscenee in a game or on a dvd/blu ray wont work, theyre mouths ove but there is not any sound coming out.
    The other guys answer didnt work as there is on linear option that is ticked but blacked out so you cant change it.
    Any alternate sloutions would be apprecitated. thanks.
I had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Posted on Apr 21, 2009
Go to PS3's audio settings, click HDMI, then manual now untick all settings e.g pcm 41khz etc. and only allow dts and dolby, this fixed it for me :)
Posted on Apr 27, 2008
Not sound work
Posted on Feb 28, 2008
Acoustic solutions lcdw22dvd95f. tuner problem
Without the DTV digital converter box.Ur tv tuner have statics video come out to the signal at all?Yes it the converter box not the tv.
Mar 17, 2010 | Televison & Video
Acoustic solutions LCD37NK750HDF TV sound ok but no picture.
If there is no picture, just black screen.. then the cold cathode (backlight) on your monitor is busted. Or its ballast transformer is burnt out. Replace it to work again.
Nov 26, 2009 | iLO LCT32HA36 Television
I have an acoustic solutions tv, i use a hdmi lead to play the ps3 on it. The volume is not working tho, the hdmi lead works on other tv's and the ps3 volume is turned on, but i cant get the volume to work...
check the hdmi out with another device that takes hdmi, the hdmi system works on its own from the av board side of the av board. has its own settings. then main board will have a large chip on the board and this is the hdmi control chip. these can go on there own and not afect any other part of the tv
Jul 21, 2017 | iLO LCT32HA36 Television
PLaystation 3 won't link up via HDMI cable
You might want to try a factory reset on your PS3 = turn it off then hold down the power button for 5 seconds it should then Beep.
there is a small memory in the PS3 that stores info about the tv that is was Initially setup on. IF you do this reset this should allow you to connect it to your Acoustic Solutions tv via the hdmi cable.
Another Tip i would do is connect it all up with it turned off then power up your appliances once its all connected.
Hope this sorts it out for you
Little Dish Fitter
Sep 18, 2009 | Televison & Video
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Acoustic solutions ctvl32w3hd
the sky remote code for acoustic solutions ctvl32w3hd 1239 (its a goodmans code ) works fine on mine
Jul 17, 2008 | Acoustic Research UltimateRemote Remote...
I cant rig up my surround sound to my tv
Run a phono cable from the tv output to a input on your system,select this input and you should have sound,if not go to tv menu for sound set up as some tv,s need the output turned up or even to be switched on.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Audio Players & Recorders
Televison & Video Logo
902 people viewed this question
Top Televison & Video Experts
Electro Med Services...
