Question about ASUS MyPal A626
4 GB Expansion (ASUS A626)
I just purchased a 4 GB card for my ASUS A626 and the unit will not read the card. however, it will read my friends 1 GB Card. Is this a problem with my PDA or the card?
Yes, my card of 4gb works perfectly, thank you very much.
From El Salvador Central América.
phone:(503)7774-2842
Posted on Mar 12, 2010
  • 108 Answers
The card format for ASUS A626 is one of the most wide-spread among PDAs – SD/MMC with SDIO support. Please be ensure that you are using only the Card that is supported by your PDA. The biggest memory card you can use with the A626 should be the most capacious unit on the market
Posted on Feb 06, 2008
  • 689 Answers
Cards 4GB in size are SDHC and an updated driver is required..
You can either download and install the SDHC patch
http://dlsvr01.asus.com/pub/ASUS/IA/Cannes/A6X6_SDHC.rar
or the updated ROM image
http://vip.asus.com/support/download/download_item_member.aspx?Model=MYPAL%20A626&SLanguage=en-us#
Good Luck
Ram memory ASUS G73SW
This is the RAM specification for your motherboard.
Memory
DDR3 1333 MHz SDRAM
• 4 x SO-DIMM socket for expansion up to 16 G SDRAM Quad Core
• 2 x SO-DIMM socket for expansion up to 8 G SDRAM Dual Core
Apr 13, 2012 | Computers & Internet
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
HOW TO REPLACE SCREEN ON ASUS A626
You have to visit Asus Service centre in you country
please visit www.asus.com and find the address of nearest service centre in your country.
Jan 23, 2010 | ASUS MyPal A626 Pocket PC
Upgrade from SB 1.1 to USB 2.0
You'll have to add an expansion card. The motherboard indicated has PCI expansion slots. You can install a 4-port USB 2.0 expansion card. You can find them at local electronics retailers including Wal-Mart and Radioshack. Or, you can get online at places like www.newegg.com.
Bret
1-2-1ComputerServices
Oct 05, 2009 | ASUS PU-DLS Server (PU-DLS/LAN/PA/SC)...
Asus mypal a626 will not stay connected to cisco
hello,
ok take a look for connection and securite setting in asus.
Sep 10, 2009 | ASUS MyPal A626 Pocket PC
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Cannot remove the calendar events
Did your friend do a "hard reset" of the PDA before she gave it to you? A hard reset should erase all user settings and data, returning the system to its default state.
The ASUS 626 User Manual (Ch. 1, Pg. 4) refers to this process as a "clean reset". The following instructions were extracted from the user guide:
NOTE To perform a clean reset, press the launch button and
simultaneously pressing the stylus on the reset switch. Then
a warning message appears. Press to do clean reset, or
press to leave the operation screen.
Performing a soft reset will not change the data in the device;
while performing a clean reset will delete all data
Mar 05, 2009 | ASUS MyPal A626 Pocket PC
Asus A626 WiFi
I fixed my problem with my D-Link DIR-625 router by going and changing a couple of things. I'm not sure which one did it, but this is what I changed:
1. Under the advanced tab turn off 'Wi-Fi Protected Setup'
2. Under the advanced tab - Advanced Wireless option:
Advanced Wireless Settings Transmit Power : High Medium Low
Beacon Period : (20..1000)
RTS Threshold : (0..2347)
Fragmentation Threshold : (256..2346)
DTIM Interval : (1..255)
802.11d Enable :
WLAN Partition :
WMM Enable :
Aggregation Limit : 8 Kbytes 16 Kbytes 32 Kbytes 64 Kbytes
TPC Max Gain : (0..50)
Aggregation Max Size : (2000..65535)
Aggregation Num Packets : (1..64)
Force Short Slot for 11N Clients :
Short GI :
Dec 11, 2008 | ASUS MyPal A626
ASUS MyPal A626 Wouldn't boot
On the right side of your ASUS A626 there is a switch that says "HOLD". Make sure that isn't flipped on.
-Sean
Apr 02, 2008 | ASUS MyPal A626
WIFI SD CARD
Test the network capability - ping your card and also do an auto detect through home network set up.
If it still doesnt feature, unplug, reboot phone and replug. shoul;d work!
Mar 11, 2008 | ASUS MyPal A626
ASUS MyPal A626 Logo
399 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
