Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Scanning with Konica 7030
How do I scan with this?
Felicia
  • 167 Answers
A very general question. Have you triede looking in the manuals to see what is available?
You can find these documetns here:
http://help.bt.konicaminolta.ca/
Posted on May 29, 2008
A konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
check if there is a paper at your exit feeder try. at the fuser.
if not. see if the paper sensors are not stuck.
Nov 15, 2011 | Office Equipment & Supplies
Who can i scan legal page in Brother DCP-7030 priner
Unfortunately this model does not have the capacity to scan a legal size image as per Specification the size is between a Letter and A4 sizes only. Please follow the link above. Please let us know if this information has been helpful. Thank you.
Aug 20, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
Konica minolta 7030 drum replacment
Is this a photocopier? If so then you will need a technician to fit this for you
Jan 02, 2009 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
132 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
