Question about Acer Aspire™ T180 PC Desktop
No sound from speakers on ACER Aspire.
I checked the book as to why the speakers might not be working and double checked that the jack I plugged into was a "line-in" jack. The speaker icon shows "Volumen 100%". I can see anywhere that the "mute" is on. HELP, please!
    Scholar:
  • 119 Answers
Have you checked the sound card from bios?is there everithing ok?have you checked the driver instaled in start/run/dxdiag?do you have a sound card onboard or a stand alone one?It may be damaged too.
check all this after you are sure that in the operating sistem,windows lets say is everything ok from control panel/sounds and audio devices.
if it is not a software problem,than your card must be replaced and for this visit a specialised Acer service.they will test and recomand you the best solution
bye bye
Posted on Feb 06, 2008
Acer Aspire 5602wlmi sound problem with Windows 8
You should look in the Default Devices section of the settings. But it could just be bad contacts in the jack plugs of the sound card.
May 02, 2013 | Acer Aspire 5602WLMI Notebook
Acer aspire one sound not working
Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
May 23, 2012 | Acer Aspire One Netbook
Speakers stopped working
go to control panel then to sound, double check and see which of your audio components is set as primary output. it's possible that it has changed. if you go to device manager in control panel you can see what type of sound card you have installed. make sure it is set to primary. also if you have multiple audio jacks on the back of the machine make sure that you have the jack plugged into the green plug.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 05, 2012 | Acer Aspire AX3960U4102 PTSFF02027 Desktop...
I have an Acer 5610-2762, and I'm having trouble with the sound. The speaker jack works all the time, but the speakers only work occasionally. when I check the speaker, through the sound check, it says it...
first point of call is the wire into the jack plug itself ,just fidddle with it,if the speakers switch on then off you know it is the solder connection of the jack plug--this is repairable with a replacement soldered correctly-this is the most common fault--second to this is an incorrectly configured (or malfunctioning) sound card
After this,sequentialy the solder connection of the socket(where it is soldered to the motherboard) could be faulty,broken
Feb 27, 2011 | Acer Aspire 5610 Notebook
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Aug 06, 2009 | Acer Aspire One D150-1587 Netbook
Acer speakers
hello, check the volume. also the jacks are color coded. green is speakers,pink is mic,blue is line in. if this does not help, consider adding sound card(this will give a better quality of sound than onboard sound) hope this helps! good luck, glen.
Aug 01, 2008 | Acer (90.18612.36B) Computer Speakers
No Sound
Hello
Please go to your control panel and double click on "sounds and audio devices" then click on "Advanced" in volume tab.
Check if the volume is muted and uncheck it, also check if the volume level is low.
Also please ensure your if your speakers need to be pluged into electricity mains or if they need batteries.
If this solved your problem please rate this solution as "Solved" or ask here again in order to find another possible cause.
Thank you
Oct 12, 2007 | Acer Aspire L100 PC Desktop
No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Sep 15, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
