Air-O-Swiss U7142 Humidifier
Problem for Air-O-Swiss U7142 Humidifier
Flashing light
By zivziv on Feb 06, 2008
cleaning light is constantly flashing despite several cleanings
Same Problem
Mar 27, 2008
-   Blinking light even after multiple cleanings for about 2 weeks, then it stopped producing mist altogether...-   Charlie90
Mar 14, 2008
-   Red "Clean" light still blinking after cleaning.-   Guest
Best Solution
posted on Nov 08, 2008
Very Helpful)
michelle1975
Rank: Apprentice
Rating: 98%, 5 votes
You have to press the power button and hold it for several seconds, and it will reset.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Air-O-Swiss U7142 Humidifier
Questions and Unsolved Problems for Air-O-Swiss U7142 Humidifier
Do you recommend Air-O-Swiss U7142 Humidifier?
Answer
Answer
Leaking. The white plastic circular ring in the base unit is cracked. This is part of the... (More)
Answer
When if fill the water tank with water and place it on the base the base fills up and leaks between... (More)
Answer
Air flows but no mist.
Answer
hi - i have a problem with my 7142 air-o-swiss humidifier - can you help?
Answer
i pushed the button, the signal shows the heat feature on, but the heat is still the exact same temp... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air-O-Swiss U7142 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
