Question about Curtis CMV41001 VCR
Cancelling program I have a Curtis DVD 7620. I have a weekly program setup which I wish to cancel. How do I do this? The remote has only 1 button "Clear" that might cover the situation but that does not work. Terry Bryant tb@persona.ca
    Novelist:
    Champion:
  • 254 Answers
That function is probably found in setup & programming. There should be an option allowing you to delete it. Your operators manual should help- if you don't have it, then check the manufacturer's website.
I know this is simplistic...
Posted on Feb 07, 2008
My Curtis remote isn't working
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Jan 07, 2015 | Curtis DVD1047 DVD Player
Need curtis dvd 1102 universal remote codes
084,029,082,077 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
May 11, 2013 | Televison & Video
Need Time Warner remote codes for a TLC TV
There are no Time warner codes for TCL tv's. You will have to perform a "code search"
1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.
2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.
3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.
4 Enter "991" on the remote. The device key will blink twice again.
5 Aim the remote at the device you wish to program and press the "Power" button.
6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.
7 Press the "Power" to turn the device back on and it will be ready to use
May 15, 2012 | TCL LE24FHDD20 24-Inch 1080p LED HDTV
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
My remote broke and im trying to get the codes for it for my dish network remote. Do you know them ???
Sorry to hear about the original remote, we would be happy to help with getting your DISH remote programmed to your Curtis DVD player. Here is a list ofcodes that should address your DISH Network remote to your Curtis DVD player: 678, 679, 683, 585, 592, and 594. Start by pressing and holding the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Curtis DVD player, thenpress the pound (#) button. If the code entered is valid for the remote, the modelight flashes three times.To check that the code works try several different functions on the remote tomake sure it will properly operate your DVD player. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, pleasetry the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 01, 2010 | Curtis DVD1047 DVD Player
My curtis dvd player model number DVD 1047 now only playes in black and white.
Curtis = JUNK. Our Curtis DVD failed after only 3 weeks (Horizonal Hold). The remote was **** from day 1. Replaced it with a Sony DVP-NS700H/B with Multi Disc Resume - WOW - a GREAT feature/ player! Cheapo JUNK is ALWAYS a poor value. Stores that sell **** like Curtis - likely sell other "poor value" JUNK as well - we'll avoid um' like the plague ... Consider it a lesson learned.
Aug 18, 2008 | Curtis Televison & Video
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis DVD-7620 (7600 series) Combo VHS / DVD Player - what is remote code?
@turnhob
your tv remote should have universal capability you can find the code on it's manual if the brand is supported
Jun 27, 2008 | Curtis DVD-7600 DVD Player/VCR
Curtis CMV41001 VCR Logo
158 people viewed this question
Top Curtis Televison & Video Experts
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
