Printer problems I work at a hotel and the printer we provide for our guests use continually jams. What can I do to fix that?
  • Martin C May 11, 2010
    Please let the users of this community know what the make and model of your printer is so that people specifically attuned that that printer can try and better help you.
    Ohiotech
    Genius:
  • 3,587 Answers
Printer jams come from one of two usual sources.
1. The paper is not fluttered(like shuffling cards) prior to inserting in the tray.
2. The paper is different, once from the other, in thickness. Most printers don't respond well to that sort of feed.
3. The rollers could be contaminated with dust, dirt, oil, etc, making the pickup of the paper a problem.
Sounds like a good cleaning is in order.
Posted on Feb 06, 2008
Alarm on No answer.
I called panasonic,
Thanks
Oct 06, 2009 | Panasonic KX-P1131 Matrix Printer
I just installed my new printer HP F4280, when gives print command in MS office it give error message MS office has stopped working
Hi Ahsan & Guest,
Thanks for sharing the problem with me.
Please first check printer installation:-
Start --> Printers and Faxes --> Right Click the printer --> Properties --> Print test page.
Problem might be Lose cartridge, Lose cable connections, Paper Jam, previous aoverloaded print que. Please Rectify all this.
There may be a hardware problem with printer itself please take help of printer technician in that case.
If this works, then start MS word, type something on page.
Click on print and select the right printer and print. It will work GoodLuck
Dear Guest, this problem might be in printing the web pages, please select all what you want to print or select nothing before printing.
Please see print preview to make sure that what you are going to print is rightly selected.
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
DUPLEX PAPER JAM
I posted previously. After buying new paper, the duplex printing is working. It is probably heavier than my previous paper, but not particularly thick (don't know the exact grade.) So if you have this problem, try buying some new paper a little thicker than you are using now.
Apr 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer keeps jamming
Sorry, dont know why my posts keeps coming up as guest and not my name (which is Garty)
i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, also seems to of worked for some others.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Mar 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Noise on my printer HP psc 2410
I have experienced this problem numerous times since owning theprinter, and usually a full reset (# and 9 on power-up) has resolvedit. Not this time, however! Following Guest's advice above, I visitedwww.fixyourownprinter.com and found the solution: cleaning the glass. Thank you, Guest!
Freddy
Nov 08, 2007 | HP PSC 2410 All-In-One InkJet Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
121 people viewed this question
jasbo
jasbo
