NEC VT47 Multimedia Projector Logo
Posted on Jan 08, 2010
How do I focus the NEC VT47 projector? I have tried to rotate the focus ring and it won't move
  • Anonymous May 11, 2010
    I have the very same problem; I lend it and on return the focus ring wasn't moving anymore;I opened it but I can't find an easy fix :-(
    I managed with a flat screwdriver to unlock the focus ring; i forced the ring applying strentgh with the tip of the screwdriver with the projector closed. The ring now moves butI can get a blurred image or a very blurred one :-(((
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1478
Points
I eventually fixed it; just a mechanical problem;I had to use strength to make the ring move again; How do I focus the NEC VT47 projector?  I have - 5586904.jpg
The arrow shows the direction of my movement; I had to use both hands; be very careful but also be aware that I had to put a lot of strength to manage to unlock it; good luck!
1helpful
2answers
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
2helpful
It will not turn thus i can not focus...the zoom ring moves but not the focus ring.
VT 595 the focus knob won't turn appears frozen other then that it works well
Audio Jack of NEC VT47 (using external speakers)
go to your menu find the volume settings. i think your volume is 0 or muted.
When I hook up my HP to an NEC projector it blows up the icons and screen so it makes it hard to see on the projected pic.
Try adjusting the resolution on you computer. I believe this is a native xga projector (1024 x 768)
2helpful
Clean filter on NEC
Hi I was looking for the same information and come across your question. I have just found this but have not had a chance to look at it yet, however if I don't reply now I might not get a chance later:
http://www.aboutprojectors.com/pdf/nec-vt47-manual.pdf
I hope it helps you (and me!)
P
NEC VT47 Cropped image on left side
Hi. You can press the auto adjust button on the projector and the image should return back into view. If not then try another resolution on your computer as it may not be compatible with the projector.
7helpful
3answers
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
NEC VT37
you auto focus or you can manually rotate the lens for focus
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
