JVC AV42PD20ES HI, our tv was working fine until an engineer came and connected our video recorder, we now have the vcr, sat digi box and a dvd recorder connected, it appeared to be working fine until we turned it on the next morning and were met with red glittery screen and then it turned black, we have sound ok. Sometimes if you leave the tv on the picture appears and seems to be ok! The engineer came back and said out Tv was faulty and we needed to buy a new one, all was ok before he did the connection work. I do hope you can help. Capprii
  • capprii Feb 06, 2008
    HI, yes, it looks red and glittery for a while and then the screen goes black, do you think is can be repaired?
    Thanks for taking the trouble to reply.
    sue
    Sniper:
  • 67 Answers
I was able to create the same condition on my plasma tv by disconnecting the upper and lower y-drives. only red pixels are lit up and it looks like glitter.
Posted on Feb 06, 2008
  • clusterfx
    clusterfx Feb 23, 2008
    Yeah it can be repaired but it's not worth it. The parts and labor would cost very close to a new tv. Most technicians won't even look at it without having you pay them first. Maybe some nice technician can give you a quote over the phone if you tell him/her the symptoms.
    i would go with lcd's next time...they last and have been around much longer.
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Sanyo VCR - further info required
Hi, as stated on other post, VCR cannot be programmed storing sat channels in memory, you can get only a unique sat input channel on VCR.
You can only record from the channel that is currently been received on Sat, you can even use VCR timer, but you cannot store Sat channels into VCR.
all you do is connecting the sat box output to VCR, and VCR will see the SAT box as input, or line 1, or AV1, or external, or something similar, depending on the model.
You cannot program VCR on sat channel, you will need to leave sat box on the channel you want to record, it will be the same on a DVD RW.
Regards
Sep 09, 2008 | Televison & Video
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Durabrand dvd/video combi
There could be at least two ways to hook in your VCR. The common way is to hook your VCR inline (between) the sat box output (RF or antenna) and the TV RF/antenna input. This will allow you to play the VCR/DVD & record whatever channel the sat box is set to. I'm not real familiar with the newer sat boxes, but I assume they output one channel at a time, thus, you can only record that channel. On the older cable or outdoor antenna systems, you could record one channel while watching another. Perhaps some sat boxes have this capability. You might do a Google search with the box Model number to see if an online manual can be found. The other hookup possibility is if your TV set has audio/video inputs & outputs. Hook these to the matching input/output of the VCR/DVD.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Electro Med Services...
