Question about Dryers
I have a Kenmore Elite Model number 110.63022100 which isn't heating. I just cleaned the vent which was a problem. I assume this has caused a problem with the heating element or thermostat. What do I do next.
  • dssigwa Feb 08, 2008
    The advice was dead on. Heating element replaced and the dryer is working like new. Only problem now is the backed up laundry.
  • 5,911 Answers
Is the drum spinning, but not heating? Or...is the drum not spinning at all?
First, we'll assume your dryer is spinning, but just not heating. If your dryer vent was clogged as you stated, it is common for the thermal cut-out (TCO) to blow. This is a non-resettable device that acts as a fuse. Once it blows, it has to be replaced. There is also a possibility that the heating element went bad, if the TCO didn't do it's job. To check, you will have to remove the lower panel under the door. There are some screws under the bottom lip of the panel that you will have to remove and then the panel should just drop down and come off. CAUTION: Please UNPLUG the dryer BEFORE servicing anything inside. There are still dangerous voltages present with the dryer turned off.
Now located the heating element. It will be on the right-hand side encased in a heater box. There are two small components mounted to the heater box housing. The one closest to the front of the dryer is the high-limit thermostat. The one farthest to the back is the TCO. The two work in conjunction to help regulate the temperature inside the dryer, as well as, protect the heating element. Locate the two wires coming off the ceramic terminal of the heating element. Unplug these two wires and do a resistance check across the terminal. If the heating element is good, it will read about 9-13 ohms. Now remove the two wires from the TCO and perform a resistance check. The resistance should read 0 ohms (or a short) if good. If the TCO reads infinite (or open) it must be replaced. The same applies the the heating element. If the TCO requires replacement, it is strongly recommended by the manufacturer that you replace the high-limit thermostat at the same time. In many cases, the two components are sold as a set. The reason being that if the heating circuits overheat, there is a strong potential that the thermostat will be damaged as well. Replacing only one of the components can result in having the replace the other a short time later.
Now, if your dryer does not spin at all, you probably have a blown thermal FUSE. There is a difference between the thermal FUSE and the thermal CUT-OUT. The thermal fuse is located on the air blower housing right under the drum, and is a white plastic component. Remove the wires from it and perform a resistance check. It should also read a short if good. If not, it must be replaced.
If you need parts, here are the part numbers:
Thermal Cut-out/Thermostat Kit (part #2821)
Thermal Fuse (part #2923)
Heating Element (part #525502)
You can find all these parts at repairclinic.com, along with the price information & pictorial part index. Just type your model number in the search menu. I hope this helps you. If you need any further assistnace, please post back with comments and let me know.
Posted on Feb 06, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 09, 2008
    Great news. Glad that I could be of assistance.
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
Coil replacement
I'm not an expert but assuming you ordered the coils for your dryer your dryer must have them. I just finshed repairing my kenmore gas dryer after about 10 minutes the gas would shut off. This is becasue the coils that are on top of the gas line before the ignigter were defective. The coils control the gas valve and when my dryer got hot the coil being defective would close the valve. There are 2 coils a 2 prong and a 3 prong. Remove the front panel to gain access to the bottom of the dryer from there you will see your coils about as round as a quarter and 10 or so high. unscrew the screws holding down the retainer and undue the electrical clip. reverse for the install. good luck!
Dec 13, 2009 | Kenmore 72802 Gas Dryer
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite model # 11063032101. It
If exhaust is blocked or restricted from back of dryer to outside of home it will cause the dryer to over heat the high limit switch. Repeated overheating will weaken the over load switch and it will need to be replaced if normal operation can not resume without restriction. Sea Breeze
Mar 26, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
534 people viewed this question
Top Dryers Experts
