SOURCE: replace waste toner container on lanier 6625
Can you verify the model number once again? If there are letters in the model number, that would help as well.
Is the copier black and white or color?
SOURCE: Sharp MX 2300N - Toner
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Testimonial: "Many thanks for your fast and accurate advice and solution. We have now ordered this unit and will install as you suggest."
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
