Question about Technics SL-1200MK2 Turntable
SL-1200MK2 Balance weight releasing?
I just bought my first sl-1200mk and i put the balance weight wrong. So it's not like it should be, now I wonder how i can take it off and assemble it right?
I know this is really embarrasing but hope some one can help!?:)
And sorry bout my bad english.
Honestly... Just Pull it back off and switch it around.... it may feel like your gonna break your tone arm but just pull at the weight and it will give before your tone arm does... but BE CAREFUL!!!
Posted on Feb 14, 2008
One channel on my sl1200 mk 2 has very minimal sound out put. I have to turn my balance selector on my reciever almost full right to balance the volume. Any insight to this problem is...
As a test, switch the right and left RCA cables from the turntable to the amp. If the problem reverses, the issue is in the turntable or with the cables. If it stays the same, its a problem with the amp.
Nov 16, 2010 | Technics SL-1200MK2 Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. styluscity@gmail.com
Jul 08, 2010 | Technics SL-1200 Turntable
How do you balance & adjust tonearm after changing stylus
turn the whole weight until arm sits just above platter.hold back of weight and turn front disc to zero. turn whole weight to spec for cartidge fitted,usually around 2.
Nov 21, 2009 | Technics SL-1200MK2 Turntable
How to install shure m44-7 cartridge on technic sl 1200.ive aproblem with the wt.,as i feel the shure cartridge is lighter then other cartridges do ihave to install extra wt. with the cartridge
No, you should not need to install extra weights. Adjust the tomearm counterweight (on the back of the tonearm).
Install new cartridge.
Set tracking force dial to zero.
Adjust counter weight so tonearm floats vertically. This is the balance point.
Dial in tracking force, 1 to 3 grams.
If you cannot achieve balance point then you may have to add weight between the cartridge and the cartridge mount
Oct 20, 2009 | Technics SL-1210 Turntable
Screws to secure spindle to Technics 1200Mk II chassis
hi its called the N2 screw,, get it here, for next to nothing!
Feb 02, 2009 | Technics SL-1200MK2 Turntable
Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 14, 2008 | Technics SL-1200MK2 Turntable
Stylus pressure set in terms of manual but arm continues to skate across vinal
Sounds like the stylus has been damaged. Perhaps when you were adjusting or installing the stylus, it might have gotten damaged. The stylus will only slide across a record like that when the actual tip is either damaged or no longer present.
Check your stylus first and foremost. If you still see the tip, then try adjusting the balance weight - the big weight towards the rear of the tonearm.
- OPTiC
DJ Pro Audio
The 1200s Experts
www.1200s.com
www.repairnyc.com
Sep 11, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
124 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
