Question about Ricoh Aficio AP3800C Laser Printer
Duplex Registration Hi, Does anyone know how to get duplex registration marks to line up. Am currently trying to print a book on duplex but the registration marks don't seem to fall on top of one another. I have got the registration setup from side to side but the centre marks are about 2mm out of register. I have set registration vert. but I can't find a horizontal setting, which I need to complete the job. eddie66
  • eddie66 Feb 18, 2008
    No, it is the registration marks when duplexing. I have succeeded in getting the vertical alignment near enough but the horizontal is out about 2 mm.
  • Eddy Key May 11, 2010
    Is it the color reg. or black and white?
    New Friend:
  • 34 Answers
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and locked print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
SP1-XXX (Feed)
1 Mode No.
(Class 1, 2, and 3) Function / [ Setting ]
1-002
[S-to-S Reg.]
Side-to-Side Registration
1 By-pass Table *
2 Paper Tray 1 *
3 Paper Tray 2 *
Adjusts the side-to-side registration by changing
the laser main scan start position for each mode.
[ -10.0 to 10.0 / 0.0 / 0.1 mm/step ] FA
4 Paper Tray 3 *
5 Paper Tray 4 *
6 Duplex *
Posted on Feb 19, 2008
Hello, I have problems with Duplex print at my SCX-4828FN since using a "new" refilled toner cartridge. I already exchanged this refilled one by an original Samsung MLT - D2092L/ELS (S/N C769B8WD4A02BHV),...
Hi, Your printer have problem with drive Clutch. To match grease. You have to dismantle the clutch and clean them. This is typical defect of SCX 4838, 4824. Cheers !!! :)
Sep 14, 2013 | Samsung SCX-4828FN All-In-One Laser...
My book fold booklet is printing upside down when duplexed!
You may need to tell word you want your printer to flip on the short side and not the long side. With my Canon printer I get a drop down menu IN WORD (not printer setup) that gives choice of: print one side; print two side flip on long; and print two sides flip on short.
Jun 02, 2010 | Microsoft Office Word 2007 Upgrade Version...
IR5570 jamming from paper deck #2 but having a 0201 jam code what possible solutions ....changed the feed sep and pu tires and also replaced paper deck #2 registration rollers going into the duplex...
Check the duplex motor that feeds the reg roller shaft - in the front of the duplex unit. I found one that was loose, when I opened the front duplex cover and moved the motor, the screw fell out! The motor gear and drive gear were not touching. Good luck
Jan 27, 2010 | Canon Office Equipment & Supplies
Can't get Oki to duplex
some of the oki's & hp's wont duplex on the network without a print server, know it's a shot in the dark but is it connected to a print server or directly to the network.does it give any errors or just fail duplex and comes out single sided?
Jul 28, 2009 | Office Equipment & Supplies
Paper Jam from the duplex into the Main Unit
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Dec 11, 2008 | Ricoh Aficio AP3800C Laser Printer
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Printing fuzzy / bleed text with fuser saying needs changing soon!
Hi the blurring maybe down to the machine needing a color registration. Press the menu button then press either the up or down arrow to Maintenance press enter or # the using the up down keys again select color registration enter or # then print registration sheet once printed select M Y C or B and input the number that is on the printed sheet that corresponds to the straightest line. Once you have done this exit and try printing.
If that doesn't work then within the driver on the computer under printers and faxes right hand click on the printer select properties. Within properties you will be able to change the graphic mode please try this.
The fuser unit will need changing as they only have a life span there are no benefits to resetting as you will need to change it anyway. If you do not change the fuser then it will break leaving you with a bigger problem.
I do hope the above works for you.
Thanks J
Dec 05, 2007 | Ricoh Aficio AP3800C Laser Printer
PRINTING BLANK
The registration and transfer rollers need replacing.
Dec 13, 2006 | HP LaserJet 4650 Color Printer Manual...
Ricoh Aficio AP3800C Laser Printer Logo
232 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
