Back to:
Tags:
TV Combos
Generic problem for all TV Combos
Philips CCB130AT02 TV/VCR combo (by 3 users)
posted by aerobicsgirl on Feb 06, 2008
Does this TV have a built in digital tuner or do I need a converter box after the DTV transition? It is not hooked up to cable.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 08, 2008
Do I need the converter for this model? I am not hooked on cable but the set has capability for it. Do I still need the converter?
Comment by dalesromeo, posted on May 29, 2008
I have a sylvania SRC2419 and don't know which tv converter box would accommodate it. There are so many out there. I would like one with remote/
Thank you!
Best Solution
posted on Feb 06, 2008
FixYa! (100)
sharcnet
Rank:Guru Guru
Rating: 92%, 399 votes
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Philips CCB130AT02 TV/VCR combo:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
Toshiba MD14FP1 14 in. TV/DVD Combo
i have a toshiba tv and certain channels have no sound and...
TV Combos
when the power is switch on ,the media receiver shows...
Sharp VT-G21 21 in. TV/VCR Combo
My television will not turn on. The wake-up timer light is...
Symphonic SC519DD 19 in. TV/DVD Combo
my tv zoom in randomly how do i fix it
Coby TVDVD1350 13 in. TV/DVD Combo
My Coby TVDVD1350 13 in. TV/DVD Combo , will not turn on...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
