Question about Xerox DocuMate 262 Path-Through Scanner
Pulls through too many pages at once
We've had our scanner for about 2 years, and now it constantly pulls through more than one page at a time, and jams repeatedly. We have even cut off the corner of the pages where the staples had been, just to "clean up" the paper to prevent jams. Any suggestions?
    President:
  • 2,072 Answers
In the scanner where it pulls the paper in, there are rubber pads that hinder the paper feed from pulling more then one sheet. Those wear out and need to be replaced.
Posted on Feb 11, 2008
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
I have a HP Scanjert N6010 that will not scan more than one page at time. If you even put in two pages it will pull both through at the same time.
The Main Problem I have found when it pulls through more than one page at a time is if the pages were stapled then the staple holes will pull all the pages together.
There is one big pickup roller in the middle of the scanner if you open the front flap, remove theat pickup roller and clean with some computer foam cleaner and a lint free cloth or a screen wipe and reboot the scanner.
Kind Regards
Aug 22, 2010 | HP Scanjet N6010 Photo Scanner
Constantly running out of b & w and colour ink despite fact that I print less than 30 pages of A4 b& w in a year
Your printer's ink could be drying out before you use them up. If you leave your printer without printing for long periods of time your ink will dry out. Try to print at least once per week this will stop your ink from drying out.
Jun 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
HP 3330 Scanner is very slow
PDF files are notoriously slow to print. You might invest in more printer memory.
Jan 16, 2009 | HP LaserJet 3330 All-In-One Printer
Pulls 2 sheets every time
Drive clutch of the paper pickup roller. It sticks.
Dec 05, 2017 | Samsung ML-1450 (Open Box) Printer
Number of Pages the fi4120c will scan
Try to get to the separation rubber and clean it.
Nov 04, 2008 | Fujitsu fi-4120C Path-Through Scanner
Incomplete feed
try correcting the page width and make sure one page goes through at a time also you can press the bottom of the paper and it will feed better
Mar 18, 2008 | Xerox DocuMate 252 Path-Through Scanner
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
Xerox DocuMate 262 Path-Through Scanner Logo
754 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
