Question about Apple iPhone Smartphone
Iphone Problem Can't seem to dial out all of the sudden. When I enter outgoing number into the keypad the numbers are not showing up at the top of the screen and I am not able to dial out. Can you help?
  • 3 more comments
  • thekylie Jun 18, 2008
    i can't seem to dial on my iphone. i hit the numbers but they just appear for a millisecond and disappear again. hence, no numbers are displayed at the top. how do i fix this?!? i'm not an AT&T user and i'm living in Malaysia.
    DESPERATELY NEED HELP!!
  • iPhoneuser0 Nov 28, 2008
    I do have the same problem right now. I cannot call use any number keypad and it returned to the home screen automatically and plus I'm not AT & T user. So if somebody knows how to solve this problem, pls let us know about that. I can't call anybody right now. desperately need help!!!
  • Anonymous Jan 17, 2009
    Hi Guys,
    I have the same problem, i am on firmware 2.2 and my keypad is not allowing me dial out, The number appears for a milisec and then dissapears and i cant see the number or even press the green button to dial out. No recent updates were done. any help will be appreciated.
    Thanks
    S
  • Anonymous Jan 21, 2009
    same
  • b2bisu Feb 08, 2009
    i have the same problem. i just bought new unlocked iphone.and now the keypad is not working.i cant dial the number .i can make call from my contact list but cannot end the call..... desperately in need of help.... and i'm not an at&t customer
    Problem Solver:
  • 5 Answers
I used INSTALLER to uninstall KATE and one other app, the name of which escapes me. Now the keypad for the phone works fine and I had voicemails I didn't even know about. Seems to be a weird conflict with third party apps.
Posted on Mar 24, 2009
I had the same problem but managed to solve it.It is caused by a game / application you will have installed on your phone, I cant tell you which one but one of them is the cause of the problem.You dont have to restore the phone but I solved it by ruthlessly uninstalling most of the games and apps I had downloaded on the iphone then rebooted.I uninstalled about half my downloads before the phone behaved normally, now its perfect.Obviously I lost of apps / games but what good is a phone if it wont phone out, It took me ages to find this solution but it works.
Posted on Feb 24, 2009
    Sergeant:
    Champion:
  • 241 Answers
You seem to have the same issue i had once before - you will need to upgrade your iphone to 1.1.3 BUT if you are not an att user you will not be able to unlock / use the turbosim to use the phone.
The baseband will be upgraded.
Hopefully you are AT&T client, then all will be good
Posted on Feb 06, 2008
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
How to dial number using iphone4s can you show me a pic
press green phone icon on the bottom, then press the keypad icon also on the bottom of the phone and this will open the keys for you to dial
Sep 02, 2012 | Apple iPhone4 4G iPhone 4
Can not get my machine to fax any document.
Hi, First of all, please verify that the phone line is connected to the right port on the printer. It's on the backside and it says "LINE" over it. If it's connected, please do as follow:
1- Insert document to send at top feeder 2- select FAX on the keypad of the printer 3-Dial the number on the keypad of the printer. Don't forget that if you have a PBX to dial the outgoing number first) 4- Press the "Black Copy" button on the keypad of the printer (it also says "START").
You then should start listening to a dialing tone and the fax starts. After a few minutes the disply should say FAX -> OK
That's it. Hope i was of any help. If so, please rate me. Thank you.
PcSimples
Mar 14, 2011 | Canon PIXMA MX310 All-In-One Printer
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
How do I do a group fax with a M20i?
NOTE: The following solution applies only when the WorkCentre has the fax feature.
Speed Dial numbers must be set up before creating a Group Dial. If Speed Dial numbers have not been set up, See the Related Items below for additional information.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'Fax Setup' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Group Dials' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until 'New' is displayed, and then press the [Enter] button.
  5. Enter a Group Dial number between 1 and 200 using the numeric keypad, and then press the [Enter] button.
    NOTE: If a 'Location No. is Registered' message is displayed, the number has already been stored as a Group Dial. Enter a number that has not been stored, and then press the [Enter] button.
  6. Enter a Speed Dial number to be added to the Group Dial using the numeric keypad, and then press the [Enter] button. The name and fax telephone number stored for the specified Speed Dial number will be displayed.
    NOTE: If a 'Not Assigned Enter Again' message is displayed, the number has not been stored as a Speed Dial number. Enter a number that has been stored, and then press the [Enter] button.
  7. Press the [Enter] button. The Speed Dial number will be added to the Group Dial.
  8. Repeat steps 6 and 7 to add additional Speed Dial numbers to the Group Dial.
  9. After all required Speed Dial numbers have been added to the Group Dial, press the [Menu / Exit] button.
  10. If required, enter a name for the Group Dial using the corresponding buttons on the numeric keypad, and then press the [Enter] button. If a name is not required, press the [Enter] button.
  11. Press the [Stop] button to return to the Standby mode.
Feb 17, 2010 | Xerox WorkCentre M20i All-In-One Laser...
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
All of a sudden I cannot make outgoing calls from my Motorola i265. ''message, the number you have dialed is temporary out of service'' which is not the case. It happens with every outgoing number I dial.
check in the top right corner of the screen. if it shows a phone icon with a 2 next to it, you are trying to call out on the wrong line. go into menu=> settings=> phone calls=> set line. make sure set line is on 1.
Jul 10, 2009 | Motorola Mobility Naztech Nextel Iden...
Can't enter outgoing phone number....I have a dial tone
  • your phone or phone company may have used or set restriction on making outgoing calls
May 03, 2009 | Lands Phones
Wont accept outgoing calls
you need to contact your service provider and let them know what going on. They probably send you another phonelike the same one you have
Jan 30, 2009 | Samsung SGH-J750 Cell Phone
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Apple iPhone Smartphone Logo
185 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
