Question about HP Compaq dc5100 PC Desktop
HP Compaq dc5000
The computer repeats 5 short beeps constantly when turned on. Nothing else happens but the beeps
  • 118 Answers
Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Posted on Feb 06, 2008
  • Mohammed  Rahman
    Mohammed Rahman Feb 06, 2008
    Can you post the type of BIOS you are using
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Continuous beeps, no display
Usually continuous beeps from an hp means the power supply unit is acting up.It is not switching on the power required for the mobo to boot up. Could also be ram prob but then the beeps tend to have a break b4 repeating. try booting with HDs disconnected. If no result. clean rams teeth with a eraser and try again. If still beeping try another power supply unit. It does not have to be identical similar will do. Once you isolate the cause of the non boot you can decide if you want to do a patch work repair or fix with originals
Oct 31, 2012 | HP Compaq dc5000 PC Desktop
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
The computer repeats 4 short beeps constantly when turned on ... power supply light is green and also motherboard light is green
Hello, depends on which make of bios you have. If you're lucky it's a keyboard error, but take a look at this page of bios beep codes.http://www.5starsupport.com/info/beep_codes.htm
regards,nicam49
May 11, 2012 | HP Compaq dc5100 PC Desktop
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
PC will not boot up. Almost did once but screen went black. Reboot doesn't help. No green light on monitor and PC makes a long slow beep over and over. I have recovery discs but when put it nothing...
Based on your description of your problem, my educated guess is that you have a problem with the system board or motherboard. Checking Compaq support site, it says that beeps are generally heard when a hardware device is not connected properly or has failed.
First thing to try is disconnect the keybaord and mouse and try to start the computer again. What we are trying to do is find out which hardware device might be involved. So start with the keyboard an mouse. If the computer still does not start, remove any periferal drives, like floppy or cd drives.
There are several beep codes, below are a few examples listed:
Beep codes common to HP and Compaq Desktop PCs The following beep codes are common to many HP and Compaq desktop computers. Use these codes first before referring to the other code lists. NOTE: Not all codes are shown. Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful Try working on this solution and see if you can get the computer to start. Below is a link to a troubleshooting page from Compaq for your computer. This can be a good reference as well.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899280&tmp_task=solveCategory&lc=en&dlc=en&cc=us&dest_page=solveCategory&tool=solveCategory&query=pavilion%20m8200n&product=3548185
I hope that this information was helpful.
Brian
Jan 05, 2011 | HP PAVILION M8200N PC Desktop
Compaq hp desktop w black screen only two beeps
your bios is posting try a different monitor if that doesn't solve it then you probably need a new computer
Aug 25, 2010 | HP Compaq dc5000 PC Desktop
I need driver controler ethernet for hp compaq dc5000 sff
HP Compaq Business Desktop dc5000 series ... All dc5000's come with: Intel 865GV chipset ... Integrated Broadcom NetXtreme Gigabit Ethernet for HP try this link for the driver you require
http://www.general-search.com/download/controleur-ethernet-hp-compaq-dc5000-sff
Apr 30, 2010 | HP Compaq dc5000 Small Form Factor PC...
HP Compaq dc5100 PC Desktop Logo
857 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
