Question about Cisco Catalyst 4006 Chassis ( 4006)
Cisco error on switch
I cannot find a explanation for the following error:
SYS-4-P2_WARN: 1/Tag 6 on packet from 00:0a:b8:e8:7d:5e port 3/48, but port's native vlan is 1
it is occurring on Cisco switch, the port that is mentioned is going to a Cisco router.
  • 56 Answers
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Posted on Feb 06, 2008
Cisco asa 5500 - sh interface - reveals switch ingress policy drops - what are these ? will they slow down traffic ?
The following is an excerpt from cisco.com defining policy drops and their possible causes:
This drop is usually seen when a port is not configured correctly. This drop is incremented when a packet cannot be successfully forwarded within switch ports as a result of the default or user configured switch port settings. The following configurations are the likely reasons for this drop:
blank.gifThe nameif command was not configured on the VLAN interface.
Note blank.gifFor interfaces in the same VLAN, even if the nameif command was not configured, switching within the VLAN is successful, and this counter does not increment.
blank.gifThe VLAN is shut down.
blank.gifAn access port received an 802.1Q-tagged packet.
blank.gifA trunk port received a tag that is not allowed or an untagged packet.
blank.gifThe security appliance is connected to another Cisco device that has Ethernet keepalives. For example, Cisco IOS software uses Ethernet loopback packets to ensure interface health. This packet is not intended to be received by any other device; the health is ensured just by being able to send the packet. These types of packets are dropped at the switch port, and the counter increments.
blank.gifThe VLAN only has one physical interface, but the DEST of the packet does not match the MAC address of the VLAN, and it is not the broadcast address
Throubleshoot these and see if any of them apply to you. Thank you for choosing fixya.com.
Dec 04, 2010 | Cisco (ASA-SSM-AIP-20-K9=) Firewall
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
New new codes for digivox ntl dublin
Hi
I am a damm fool. Had moved the cable at the back. Sound and vision great now. Thanks for codes
J
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Codes
Dec 04.2008.
NTELL
0=3F B8 36 62 72 E5 E2 76
1=35 5E D6 40 6E AA 99 41
TW
0=C0 F6 61 87 91 F9 67 57
1=F0 83 35 E5 28 40 49 B2
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
Hi can anyone help please? Has anybody got todays 4 Dec star view codes.
4.12.08.
ntell
tw
Anyone got codes for 4th December??
4.12.08.
ntell
tw
Code for starview
4.12.08.
ntell
tw
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox ex1000 sl starview3
4.12.08.
ntell.
tw
Pure ntl keys 3rd dec
1=DB 7A A2 F2 4B 12 7E 59
Please advice me as soon as uyou can ..thx
Start troubleshooting the problem by checking the physical layer (Plugs, Jacks, Cables). Replace them with known working equipment.
Once you have traced the line from your Cisco to each other end (through to ISP, and to network switch), then reset your error counters, by restarting the cisco.
Check the ethernet interfaces on the network switch and the Cisco. Make sure they are both set to Autonegotiate or both set to the same settings like 100mbs Full-duplex. If they are not communicating the same way lots of errors will be generated.
Nov 09, 2008 | Computers & Internet
Open Questions:
Cisco Catalyst 4006 Chassis ( 4006) Logo
623 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
