Question about Ovens
Bottom oven coil placement and oven cleaning directions
Recently I have had 2 small oven fires. Superbowl chix wings ran over the pan's edge- so not only does my oven need cleaning, but I also see that the bottom electric heater coil no longer has a V shaped support on the left side to hold the coil off the bottom of the oven- which starts fires. First- I cannot find my manual w/ directions to clean the oven.I have a Kenmore glass top stove- about 7 years old. What do I do? Second- How do I get the coil to lift off the oven floor and stay that way? The V support is nowhere in sight? Thanks tons if you can find a solution for me
SOURCE: replacing glass top stove HELP!!!
Same problem, and we continued to cook on the stove and the cracks just spread, eventually creating a couple of holes! A good solution would be greatly appreciated.
Posted on Jun 02, 2008
SOURCE: Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Posted on Oct 15, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
  • 71 Answers
SOURCE: whirlpool oven caught fire while cleaning
just scrape out the residue and clean it again.
Posted on Dec 12, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ultral Bake Self Cleaning Super Capacity electric oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Candy Built in double fan oven bottom oven not getting hot
Cheak the coils. Do a continuity test also look for signs of an electrical short(small scorched area) and clean the contact where the coil attaches to the appliance.
Apr 17, 2014 | Candy Ovens
How do I take off the outer glass on oven door on a frigidaire oven model FEFL74ASG
Good Afternoon clynns108 - Thank you for your question. Here are some generics steps to help you remove the door to your range or you may reach out to a professional directly to further assist you:
Tools needed: Phillips head screwdriver or small quad bit driver.
CAUTION: Edges of door may pose a cut hazard, use gloves or heavy cloth when grabbing edges.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
Jun 26, 2013 | Frigidaire Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool oven caught fire while cleaning
Dec 12, 2008 | Jenn-Air Electric Double Oven
Smoking Kenmore
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
Oct 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Range is not working
i know it sounds obvious but have you checked you oven fuse or circuit breaker - ie in your fuse box?
Apr 17, 2007 | Whirlpool RBD245PD Electric Double Oven
Ovens Logo
386 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
