I just purchased a used freezer and I am pretty sure something is wrong with it. It runs all the time, at first I thought that was natural cause we were putting fresh meat in it. But it has been weeks now and it is still running all the time. The temperature stays at 12 degrees. I tried turning it up higher and it actually heated it up so I have it on number 2 and as I said it stays at 12 degrees and runs constantly. What do you think is the problem?
if its running all the time there is a system fault it strugles to pump gas. you will need a system tech to repair this. if it has r12 on the label afraid to say it is then scrap
frigidaire freezer elite don't know what the two swithes along the top are for the one that lights...
(More)
frigidaire freezer elite don't know what the two swithes along the top are for the one that lights orange is for fast freeze i think
(More)
frigidaire freezer elite don't know what the two swithes along the top are for the one that lights orange is for fast freeze i think the freezer forms to much ice even set at medium any ideas ?thanks
i own a 14 cubic upright 2 yrs old now, i moved and after defrosting i now cannot figure out the set...
(More)
i own a 14 cubic upright 2 yrs old now, i moved and after defrosting i now cannot figure out the set temp for a normal freeze level to prevent frost burn.what is a good setting
Zanussi zx99 5w freezer compartment not freezing properly but remaining around -1. The temperature...
(More)
Zanussi zx99 5w freezer compartment not freezing properly but remaining around -1. The temperature alarm goes off after a short time. Fridge works ok? I checked the fan is not iced up and it is ok? Any ideas?
I have a frigidaire fridge with top freezer model #GLRT13TEW4. The freezer was icing up and had...
(More)
I have a frigidaire fridge with top freezer model #GLRT13TEW4. The freezer was icing up and had frost hanging from the top. So I replaced the defrost censor and timer. It worked great for one day. It turned off automatically and I was happy. Now its freezing up again,it won't seem to stop running and it's not getting cold in the bottom. What else can it be?
