Question about Frigidaire GLEQ2152ES Electric Dryer
Vent placement can the vent be moved from the back to the side?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    If there is a side panel pop-out it can. You will also need an elbow adapter to reroute the vent line behind the dryer, to turn towards the side of the dryer. Most dryers have an option to exhaust from the back or the side.
    Scholar:
  • 178 Answers
Keep in mind, a new dryer at peak performance is only able to exhaust air in a "STRAIGHT" line 90 feet away. The more bends you add to the exhaust that are unnecassary, will decrease the performance of your dryer.
Please don't forget to rate "jsrock516's" solution, His is perfectly on point.
Posted on Mar 19, 2008
How can i replace the back plate of my dryer with a flat one will not fit in space for hook up
Not likely such a thing. The funny shape probably has something to do with the air passages.
Mar 25, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have mislaid the instructions for my Genesis Miami gas fire, and need to relay the ceramic logs. can anyone please help?
This will depend on whether the fireplace is vented or is vent-free. Vent-free gas fireplaces are sold as a kit with the valve, burner, media (logs, glass, shapes, etc) all designed for a particular placement to work together to reduce dangerous chemicals. A vent-free burner and valve cannot have the logs removed and replaced with some other type of ceramic gas log because the exact placement of the logs is designed around the ports in the burner where the flames rise to minimize carbon created from the flames touching the logs.
If your fireplace is vented then the pull of the flue will remove dangerous fumes created by the same placement so there are no rules about re-arranging or replacing "media". If the fireplace is vented then you could use other log-placement-guides to identify the type of log and where it belongs with little worry because vented logs are designed to be able to have some adjustment anyway.
If vent-free and without a manual, an educated technician should do this for you because the BTU setting on the valve must be compared to the types of burners, port placement, size of ports, amount of ports and flame height. After this examination, someone familiar with the various hidden "tongue-and-groove" etchings in different types of gas logs can figure-out where to place the logs. They may have to test the fireplace burning once or twice to get it exactly correct but once you understand the idea of how a vent-free gas log diminishes the carbon-output of the amount of gas flowing through the burners then it is only a matter of watching the flames to see where the logs could be and comparing the size and layout of the logs to find the best fit.
Feb 02, 2014 | Grilling
How do i rotate tires on a 2008 saturn outlook
you lift the car up on jacks so that the tires are off the ground, then you put jack stands in placement. then you loosen ONLY THE BOLTS ON THE TIRE IN THE AIR remove the tire let the car down on to the jack stands, and move the jack to the next and do the same what you do is take the passenger side back tire and switch it with the drivers side front tire. then you take the drivers side back tire and switch it with the passenger side front tire. make sure the bolts are tight as you can get them then you are done. i hope this information helps. Be careful and drive safe!
Feb 27, 2011 | Saturn Outlook Cars & Trucks
Hi, I have a small Williams direct vent heater 14k btu that i want to install. for ideal placement, the double wall vent will be against the stud not centered. is this a problem? also can the existing...
The vent pipe CAN NOT touch the wall stud. You can cut back the fiberglass insulation, but it must be a minimum of 6" away from the vent pipe on all sides.
Jan 26, 2011 | Heating & Cooling
Cylinder 5 placement?
if you have the V8 gas engine, the cylinders on the passenger side from front to back are #1 #2 #3 #4 the cylinders on the driver side are from front to back #5 #6 #7 #8. if you have a V6 gas engine the cylinder placement is passenger side from front to back #1 #3 #5 the cylinders on the drivers side are from front to back #2 #4 #6. if you have a diesel V8 engine the cylinder placement is passenger side from front to back #1 #3 #5 #7 drivers side from front to back #2 #4 #6 #8 and last but not least if you have the V10 the cylinder placement is passenger side from front to back #1 #2 #3 #4 #5 and driver side from front to back #6 #7 #8 #9 #10.
Dec 24, 2010 | 2001 Lincoln Town Car
My heat works on passenger side but not on my driver side nor defrost, which blows out cold air
Back behind and under the dash panel is a venting system. In the venting, there are blender doors. These doors move to different positions for different air flow directions. These doors are moved by acutators. These doors can get stuck! The actuators that move them can also become faulty but not as common as the door getting stuck. The worst part is removing all the venting to get to the blending door.
Nov 08, 2010 | 2004 Chevrolet Monte Carlo
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
Heating / heater issues 2003 sonoma
CHECK FOR VACUUM LEAKS IN ENGINE BAY ON PASSENGER SIDE FOR BROKEN CONECTIONS
Jan 26, 2010 | 1998 Chevrolet S-10 Pickup
How do I change the rear vent outlet on a Kenmore dryer to the left side?
If it's designed to change, there will be metal plate on the side that you remove and place over the back outlet (remove vent hose), then move the vent hose to the side and hook it up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Dryers
Central air running all day and not cooling properly...
Did you fix the problem with the fan. Some times the placement of the fan blade up or down influences he air flow. May not be moving enough air across the coil. Sounds like it is over heating the compressor. To much amperage. You also may be losing conductivity of the condensor. When they get ols the fins go bad and loose conductivity. Also check capacitor it may be weak and causing compressor to pull to much amps. The capacitor starts the unit and also lowers the running amps by pulling the start windings in phase with the run winding. Russ
Jul 18, 2009 | Heating & Cooling
Frigidaire GLEQ2152ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
