Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool refrigerator waterline is clogged
How do I clean out the waterline to the freezer so that the ice maker will make ice again?
  • 958 Answers
Go to the back of the ref, trace the incoming water line, it should go to a two pc solenoid valve. if you press water at the front, one of the solenoid should click. the one that didn't click is the one for the ice maker. see if you can detach the water line that comes out of that solenoid. that line goes to the ice maker. you can flush it with water to clean it. be aware that a lot of water would be overflowing inside the ice maker . i hope i was able to solve your problem..
Posted on Feb 16, 2008
Automatic ice maker not receiving water to make ice. Checked and clean line from water supply valve to refrigerator. Checked ice maker and all seems well/normal.
first thing to check is the waterline going into the fridge, unhook the waterline and see if water is coming out. make sure you locate the shutoff before you take it apart!! if you have water going to the fridge then you could have a frozen line issue or an ice maker issue. more than likely the saddle valve got clogged up with something. close the saddle vale all the way then open it back up and test it then.
Aug 04, 2013 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stopped producing ice. Turned off unit overnight to melt any possib. frozen secions in the line but still no ice.
Hello
Have you checked the waterline or water filter for clogs?
Also there is a solinoid in the back of refrig for water fill for ice,it may be stuck or not working.
Apr 13, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Waterline Rattling AND DIRTY ICE CUBES
Sound like a clogged valve or a dirty water filter. Change the filter then try it. Good luck.
Nov 09, 2009 | Refrigerators
I have a whirlpool refrigerator where water pools under the veggie crispers. It looks like it is coming from the freezer. The unit does not have an ice maker and I suspect a drain line is clogged. Any...
Freezer on top? If so remove rear panel from freezer inside and check drain under evaporator. If clogged, use hot water and turkey baster to squirt water and thaw out drain. DO NOT use sharp instrument to pry ice out. You can use a blow dryer to help thaw as well. Turkey baster helps to jet hot water in drian.
Jun 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore side by side refrigerator freezer not making ice
sorry if i sounded rude i just couldn't read the entire post it just trailed off...
if it not the water valve then it is either the ice-maker is bad or the waterline going to the ice-maker is frozen or clogged.
sometimes the water valve will slowly leak a small amount of water to the ice-maker and this will freeze in the large tube going to the ice-maker from the back of the refrigerator. this will block any more water from coming thru.
hope this helps
Jun 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker wont make ice
It is quite possible that the water line which feeds the ice maker is frozen. Whirlpool manufactures a "REPLACEMENT" water line that solves this problem. Fortunatly our problem occured while the refrigerator was still under warranty. I would suggest that anyone owning a Whirlpool product purchase the longest extended warranty available! They USED to manufacture a quality product. But I guess they just don't care about the consumer any longer. It is all about money!!
May 16, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
127 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
