Question about HP Compaq ProLiant ML530 Server
SERVER PROLIANT ML370 DON'T UP
WHEN I STAR I SEE THE FOLLOWING MSG
172 SYSTEM CONFIGURATION MONVOLATILE MEMORY INVALID INITIALIZACION ABORTED
PLEASE HELP ME
    Novelist:
    Scholar:
  • 117 Answers
This means that the non-volatile memory on the motherboard (also called "BIOS memory", or simply "BIOS" has got corrupted. This may be because the tiny battery on the motherboard is dead and needs to be replaced (I can't remember offhand if the ML370 has a BIOS backup battery, so that may not be it). In any case, you need to go into the BIOS setup program as the server starts up, correct any errors you find there and then Save Changes. You may find the only option initially is to Reset to Defaults. If so, accept that, save it, then go back into the BIOS setup and customise as necessary.
Posted on Mar 23, 2008
Increase processing speeds ProLiant ML370
Only the obvious like CPU, RAM and network. You can check your specs against these possible configurations.
http://h18004.www1.hp.com/products/quickspecs/11450_na/11450_na.html
To be honest, don't see 64 Bit support so it may not make a difference, because of 32 Bit OS limitations.
Dec 11, 2012 | HP Compaq ProLiant ML370 G3 Server
Hp proliant ml370 G6 ethernet controller, base system device and IPMI interface not configured properly
Correct it or disable it. It's just a warning. Check SNMP setting for traps.
Besides you should be using the Smart Start with Insight Manager on HP servers.
Oct 20, 2012 | HP ProLiant ML370 G6 Server
Compaq ProLiant ML370 G4 (374490421) Server - Windows xp issues
Servers need the Drivers for the Drive array card.
The server should have come with a smartStart CD that has the drivers for it.
You are NOT going to get another OS on this machine unless you load the drivers for the adapter.
... and why put XP on a Server? that's not the optimal OS for the hardware.
Dec 12, 2011 | Compaq ProLiant ML370 G4 (374490421)...
Hiii.....windows server 2003 installed in my hp proliant ml370 g3server.the server is thermaly overheated and restart itself.firmwares are updated & os is formatted n re installed.all cooling fans r...
You may need to reapply thermal grease to the cpu/heatsink combo. Over time, the grease will disapate and needs to be reapplied. Also, if your memory cards are very hot, you can add heatsinks to those to assist with cooling. And lastly, you may check to make sure that your power supply is the correct wattage for your system. A low 350W power supply trying to push a 780W system will create a strain on all component parts.
Good Luck
C2Solutions
Nov 03, 2011 | HP Compaq ProLiant ML370 G3 Server
Error 207, invalid memory card configuration
The Memory were installed in an incorrect order. The Memory must be interleaved for the server to work, Follow instruction on the cover of the server.
Jul 15, 2011 | HP Compaq ProLiant ML530 Server
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
HP Compaq ProLiant ML530 Server Logo
658 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
