SOURCE: puk code for my401c
You can get your PUK Code from your service provider. Should be a
quick call after they verify your account info. Unfortunately there is
not DEFAULT PUK Code and provider is the only one that can tell you
what your SIM PUK was set to.
Please don't forget to mark if this solution solved your issue.
SOURCE: Charging Sagem my401c - error
Charging errors occur when the phone charger is sending an incorrect voltage to
the phone, or that there had been a contact on phone charger connector.
You can temporarily restart charging by unplugging and plugging back the charger, but on the long run this can damage the phone.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
