How to hook this monitor onto my computer
What software do I need to load, where can I get it, is there a user guide available and what input and output cords do I need. Message keeps coming up that video input 20 sub no signal?
During the first 30 minutes it appears that the screen times out and goes black even though I am typing on it?
  • 4 Answers
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Posted on Feb 06, 2008
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: https://pinreg.portrait.com/index.php?OEM=gwy&PRODUCT=dtune&ULANG=enu .
The EzTune software is available here: http://oem.portrait.com/dtune/gwy/enu/upgrade.html .
The user's guide and other documentation is available here: http://support.gateway.com/s/MONITOR/7005574R/7005574Rnv.shtml .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
Ba745 user manual
I'm sure that there is some special software available, but its unnecessary. You can just plug them in and have a listen. Sorry, I'm not sure where to find a manual.
Mar 19, 2010 | Boston Acoustics BA745 Computer Speakers
It says "input not supported" whenever i change the resolution higher than 1280 1080..i changed my vga card to my onboard one...cause at least here i can see everything clear with the resolution of 1280...
hi there,
looks like windows does not know how to handle the monitor.
You may try to disable the onboard graphic card in the BIOS before
hooking up the monitor to the nvidia card. then try to run windows in safe mode(by pressing F8 when booting up), it'll run windows with the lowest available resolution, which will be supported by the monitor.
Now download appropriate driver for monitor, install and reboot.
That should do the trick
good luck
Sep 29, 2009 | HP w17e Monitor
Camera trouble
Here is the driver from Polaroid's website for your camera. i633 Driver It should allow you to download pictures from your camera.
Also, incase you need it, here's a link for the user manual. User Guide (English) It should describe in greater detail how to download your pictures.
Mar 09, 2009 | Polaroid i830 Digital Camera
I bought a new computer and it isn't recognizing my monitor (blank screen)
Most monitors use software that you load onto the new computer. Look for a disk or hook up the old PC to download it.
Jan 10, 2009 | Samsung Syncmaster 940BW LCD Monitor
No picture on monitor when hooking up for the first time
There are control buttons on the side of the monitor. Are you sure you have pushed the button to power the monitor on?
If so, this is the troubleshooting step for No Image on that monitor:
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
You can view an online copy of the user's guide here: http://www.westinghousedigital.com/pdf/60_User_Manual.pdf
I hope this provides a solution to your problem. If not, please reply with a report of the steps you've taken to work through it, and we'll try to sort it out.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
I hope this help you to
Dec 19, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
Lost manual
There is no much to hook up, you hook up the RJ11 phone connector at the back of the printer to the phone line.
Install printer software onto the computer.
Then connect printer to computer using USB cable.
See here , there is user guide for all x7300 series:
User's Guide
see also
Lexmark X7350 Top 20 Questions
Here also notes on how to set up fax
Lexmark X7350 - fax problem
Sep 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
How to hook up cord
You may go the link below and get the Camera user guide as well as the software user guide so that you can follow the directions on downloading the pictures onto your computer
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=11158
Sep 06, 2008 | Canon PowerShot SD600 Digital Camera
Wii Computer Hookup
you need a faster computer to fix this, the delay is caused by the computer coding the incomming signal.. any way why would you want to go via the computer anyway (unless you wish to capture what you are doing (the lag should not matter for this). If you are just trying to put the display of this onto the monitor, there are probably better ways of doing this directly to the monitor.(rather than going through the PC)
Aug 18, 2007 | Nintendo Wii Console
Computers & Internet Logo
471 people viewed this question
Alun Cox
David Payne
David Payne
