Question about EliteGroup 741GX-M Motherboard
Bios reads wrong speed
Hello i have a 2800 xp athlon however the bios says 1600 windows says 1600 also i believe it is working faster than this speed ..what gives on this?The other is i want to install my other hard drive take out the original both xp both 40 gig i install it the bios reads fireball 40 however it doesnt go into windows any ideas really appreciate thank you chuck
    Scholar:
  • 119 Answers
You have to find in yor bios the section where to change the fsb and multiplicator factor of the cpu.I had same problem with an athlon 2400++...you have to upgrade it from 100 to 133 or 166 depending the case.
its   a simple routine work..just find the section in bios...explore it look for this cpu options..I cant tell you exactly where in bios because the bios version is differen from board to board..
and for the second problem
you have to make the hard with windows a bootable option
you may do this from bios too oor from the cable coneting the hdd with the mainboard...options slave/master.cable select..
however you have to set it like:"boot from...." from the bios
good luck .tell me how it worked
bye
Posted on Feb 06, 2008
Are any of these processors fast and which one is faster
I think I helped you yesterday and we came up with a solution that Athlon XP 2200+ is faster than 1350+.
Jan 03, 2010 | EPoX EP-8KRA2+ Motherboard
CPU (processor) speed dropped to 1.09GHZ
Go back into the Bios and change the settings back. If this does not correct the issue you may have another issue. If this is a laptop you can reset the bios by locating the Bios reset switch, usually appears as a pin hole on the bottom of the computer, if this is a desktop then you need to use the Bios Reset jumper on the motherboard. It sounds as thought Windows is not reading the CPU type and speed correctly so you need to undo the change you made to get it back up to speed.
Aug 23, 2009 | AMD Athlon XP 2600+, 2.13 GHz...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Sume files wont transfer with a fresh install of
hi im josh in cebu phils. Friend if some files wont transfer during the installation. the problems are centered to your cd installer or your optical disk drive. try change the cd installer if it is too scratchy or if your cd is good.try to change your optical disk.try use the faster one sothat you may done easily. good luck hope i helped you.pls.vote me if it helps you so that i will know.thnks.
Feb 22, 2009 | EliteGroup ECS KM400-M2 (3.0) WITH AMD...
GA-7N400-L
Bartie,
First we need to properly identify your processor. You can go to AMD's website and under their Support and downloads page download a utility that can properly Identify your CPU Through codes it can read off of your chip.
If it is an Athlon 2800 this tool will tell you so. (Then it is likely your BIOS on the Motherboard just isn't recogniing it properly)
If it is an Athlon 2600 (Which I think is the more likely one) You may have purchased your Athlon from a less than reputable dealer. Who either remarked the chip themself or purchased it from a remarker at a discounted rate.
OK so now your wondering what is "Remarking" . This is when a chip dealer aquires a large amount of lower end chips then modify it by jumping some leads on the chip making it run beyond its intended rate (A process called OVERCLOCKING) and then prints a higher end processors stamp on it allowing them to sell it at a higher cost.
I hope this helps you
Dave
Nov 15, 2008 | Gigabyte GA-7N400-L Motherboard
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
Sempron 2800 cpu speed
hey, here is the latest bios witch is required for your new sempron!
http://download.aopen.com.tw/userdownload_List.aspx?RecNo=9923&Model=vKM400Am-S
Dont foget to rate the solution as fixya! Thanks
If you need more assistance let me know, I'm here to help
Apr 02, 2008 | AOpen vKM400Am-S Motherboard
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Feb 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Athlon 2800+ XP-M runs at 606 MHz
1. Check your battery, 2. Press CTRL+F1 or ALT+F1 while you are in the BIOS. 3. Update your BIOS Microcode and CPU Code.
Sep 20, 2007 | AMD AXMJ2800FHQ4C - Athlon 2800+ XP-M...
BIOS DISPLAYING INCORRECT CPU SPEED
Hi, I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties. To upgrade the BIOS: 1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown; 2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | Soltek SL-75FRV Motherboard
EliteGroup 741GX-M Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
