Question about Olympus Stylus 410 / ? 410 Digital Camera
Card Reading Write Protected
All of a sudden every time I power up my 410, it reads Wite Protect! on the screen and beeps real loud and long at me. I don't know how the card could be "Write Protect!" suddenly. How do I unprotect it? Is the card or the camera bad?
  • 871 Answers
Hi there
some card do have a physical lock onto itself to protect files.
please check your card and look for a small switch, its usually at the side. click it up or down and try re inserting it to your cam. if this still isnt any help, it must be a setting on your cam.
hope this helps. :)
Posted on Feb 06, 2008
My camera says Write Protect! And my memory card is unlocked..it appeared when i was uploading pictures and all of a sudden `write protected`appreared and I cannot use my camera or take any photos...w
Have you tried a new memory card,or reformatted the existing one?
Or go on the menu on the camera and restore all the original factory settings?
If none of those work it might be time for a new camera!
Mar 23, 2014 | Olympus Tough TG-310 Digital Camera - Red...
Push power protect
Most likely you shorted out the amp ic. This will need to be replaced before the unit can be used again.
Jan 06, 2013 | Audio Players & Recorders
It reading protected card every time i inserted
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 02, 2012 | Cameras
My reebok treadmill makes only three beeps when you hit the sensor buttons
Plug in power cord, remove key, hold down speed+ and stop buttons, replace key, release buttons, press stop once, press and hold speed + until max. treadmill will run to top speed (s9.80 should read out 11.8 to 12.5.) It took a couple of times to get this to work for mine, but now it is OK. If unit does not run after several attempts then the console is probably bad and will need to be replaced ($410). Get another treadmill ! If it does run the console may still beep - problem is with IFIT card. You can get rid of the beeps by opening the console and unplugging the IFIT cable from the computer card if you want.
Feb 06, 2011 | Sport & Outdoor - Others
When I turn on the lap top it beeps real loud. Windows won't come on
it beeps 4 times but has power and screen remains blank
Jan 09, 2010 | Computers & Internet
Memory card is protected????
Move the slide switch on the side of the card.
Oct 06, 2009 | Nikon Coolpix 5700 Digital Camera
Write protect error olympus c 150 (cant get rid of read only)
Hi!
You might wanna check on your memory card. It could be that it is currently on write-protected mode. What you want to do is to check it now and then look for something like a push button. If its on the top position, push it downwards. Vice versa.
Aug 29, 2009 | Olympus Camedia C-150 Digital Camera
Card protect message doesn't allow any activity with camera how to remove?
Hi there
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 25, 2009 | Toshiba PDR-4300 Digital Camera
"Write Protect" on Olympus FE-115
Check the manual to discover how write protect is achieved with your particular camera/card Some card rely on a silver foil stick[Smart Media] other have a switch. Compact flash rely on a control on the camera. So you will have to have a good browse through the manual - do not forget that there is a Full manual in PDF on the software disk.
Aug 20, 2007 | Olympus FE-115 Digital Camera
Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Nov 29, 2006 | Nikon Coolpix 5200 Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
151 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
