Hi
Open the scanner and make sure its support locks in place.
Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
Press the Stop button again.
If another cartridge is low or expended, it moves to the teardrop position. Press the Stop button again to see if more cartridges are low or expended.
If no other cartridges are low or expended, the print head moves to the replacement position on the right.
Open the cartridge cover.
Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
Before opening the new cartridge package, shake it four or five times.
8.
Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
9.
Remove the yellow tape from the bottom of the cartridge.
Caution:
Do not remove any other labels or seals, or ink will leak.
10.
Insert the new cartridge into the holder and push it down until it clicks into place.
11.
Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
12.
Release the scanner support and close the scanner.
13.
Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
