Question about Microsoft Windows 98 for PC
USB PORT FRO FLASH DISKS
I am using windows 98 (Operating system) i am trying to open my flash disk but it cant open it is not responding in any way. What could be the problem?
  • Anonymous Feb 07, 2009
    Ok same Problem
  • 983 Answers
I hope u have downloaded the driver from the net and installed and then u r trying...
may be there is a problem with windows 98 os so hust reinstall it... just it takes 10 to 15 mins to reinstall and u will not lose any file... it will ask "do you want to keep the files" just give yes and then give a try..
if u r trying with installing the software then just download it from the net and install and then try...
after that also if ur system hangs means then just try in other pc where windows Xp is there... if it does nt works means then may be ur flash disk read and write cycle is over ...
for the flash disks there will be limited read and write cycles so...
Posted on Feb 06, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 06, 2008
    if it works in other system means just upgrade ur os to windows xp and then try... if it does nt works means check the usb port is enabled or disabled in bios settings... make it enable if it is disabled and if not then may be ur port is not working it s confirm ... try inserting in another usb port ...
Cant detect hdd
Hi Martin...
The problem is being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled. to solve the
problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for most users.
External hard drive can not be recognized, are more common on computer
failures, what's the reason caused this failure?
1, Setting the CMOS parameters
If you never used the USB external device, there may occur the case:
The system can not detect USB hard drive even if the driver is properly
installed, which was mainly due to the motherboard CMOS default port is closed, if not set to
open state, it naturally Windows can not detect the external hard drive. In order to solve this
problem, we can re-boot into the CMOS settings, and set "Assign IRQ For USB" to "Enable" in
"PNP / PCI CONFIGURATION" column, now the system can be assigned to the USB port available
interrupt address.
2, Power shortage
As the USB drive need to consume some power when it at work, if directly through the USB interface
to take power, the power supply may be not enough. Thus, almost all of the external hard drive
comes with a separate external power supply or a PS2 keyboard to take power transfer interface,
at this time you should connect external power supply or through the transfer cable ps2 connected
to keyboard to ensure that it have provided adequate power to the external hard disk,
recommended that you should ensure the external hard drive have adequate power supply when you
use it, otherwise, the external hard disk is likely to be damaged due to insufficient power
supply.
3, USB extension cable fault
USB interface type does not match the external hard disk interface ,this case caused it can not
be used. For example the standard USB interface of the computer configuration is 1.1, while the
external hard drives purchased are USB 2.0, which requires the cable connected computers and
external hard disk must support USB 2.0 standard. Because high-speed mobile device plug in a
low-speed hub, the device may not be properly installed, and some people use external hard disk
while using USB flash drives, For convenience, they directly used USB 1.1 standard cable that
supplied by USB flash drives, as a result, the USB 2.0 standard hard drive not be recognized
correctly. Just replace it by the USB 2.0 standard cable can solve this problem.
4, Windows version is too low
Pre-Windows 98 operating system does not support USB peripherals, so in any case to install the
driver, set the CMOS parameters are unable to make normal use of external hard disk. In this
case, one solution is to upgrade the operating system up to Windows 98, another way is to
Microsoft's official site, download the appropriate patch to make it can identify mobile hard
disk.
5, The system is set incorrectly
When installed driver, the external hard disk icon will be seen on the Device Manager for some
Windows 98 users, but the Explorer does not include the corresponding letter identification,
which is improper system settings. In the Device Manager, double-click the Hard Drive icon, and
click the pop-up window in the "Properties" button, and you could see disconnect, could be
deleted, synchronous data transmission and Int 13 unit four options, of which "could be deleted "
is no tick in front of the system, and simply check this option to restart your computer, you can
see in the Explorer, the new external hard disk drive letter.
While the failure of the external hard disk does not recognized are more the reasons, but
generally not the USB interface or external hard disk's own fault, so it requiring us to consider
some more from around the association when exclude it, I believe you can successfully use the
external hard disk.
Hi I had the same problem and solved it like this assuming that you are running windows xp
With your external casing powered-up (it does not get power through USB does it?) and your WinXP
PC running, plug in the USB.
You should hear 'chime', what happens then?
If harddisk is recognised here, but does NOT have a drive-letter and cannot be seen in Windows
Explorer, the answer is in Windows Disk Management
Go Administrative Tools > Computer Management > Disk Management. ( on left column)
Maximize this page. Physical Drives appear at the bottom; Logical Drives at the top.
Hopefully your drive will appear at the bottom (physically), you must then 'import' it into the
Windows installation
; Windows will put its 'signature' on the drive and assign it a logical drive letter :^)
you can try to format it here if it is new and has no info on it , check back to My computer and see if present.
Mar 20, 2013 | IBM FRU PN 49P1599 Desktop Motherboard
Convert usb raw drive to fat drive
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system. You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting. You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory b> http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html Format USB flash drives with FAT, FAT32, or NTFS partition types. Plug the Flash drive into a USB port on the Mac. Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder. Double-click the "Utilities" folder. Scroll down to the Disk Utility program. Double-click on the Disk Utility program to launch it. Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen. Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen. Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name." Click the "Erase" button at the lower right corner of the Disk Utility program's main screen. Click the "Erase" button in the pop-up confirmation window that appears. Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right. Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program. Remove the Flash drive from the USB port of the Mac. b> Format Flash Drive in FAT on a PC b> Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer." Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage." Select "Format" from the pop-up menu. Select "FAT32" from the "File System" drop-down menu in the window that appears. Click the "Start" button at the bottom of the window. Click the "OK" button in the confirmation pop-up window that appears. Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears. Right-click on the icon of the Flash drive that is on the desktop. Select "Erase" from the pop-up menu. Remove the Flash drive from the USB port of the PC. Hope this helps.
b>
Dec 07, 2012 | Corsair Memory Computers & Internet
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My flash disk does not format what is the problem? i put the flash in the windows xp system port it becomes recognised by the system i try to open it ,it tells me the disk is not formated do you want to...
Your flash disk has been infected by virus that is why you are unable to open the flash drive. The best thing you can do is to download a good antivirus such as MacaFee or Avira or scan the flash drive for virus.
An alternative thing you can do is to insert your flash drive into a linux operated pc such as Fedora, Ubuntu, Open Susie or Redhat and then delete all the files in the Flash drive and format it
Apr 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I am trying to save data from an old computer that uses Windows 98 to a data stick through a USB por but am told it does not have a device driver
well...the new flash drives or usb drives are not compatible with windows 98 nemore buddy..
i wuld suggest either try to search for the device drivers on interent, which wuld be hard to find for sure
OR
take this hard disk, connect this with some other computer with another operating system, copy all data easily then.
Nov 01, 2009 | Microsoft Windows 98 for PC
MY PENDRIVE IS NOT GETTING DETECTED
hi im josh in cebu phils. friend if not detected the problem is you usb port or the flash disk. if you tried using your flash disk in other computer and you are sure that it is functional. then go to your usb port.check the connections.check also the confg.from the device manger if the printer port works. then dont forget that windows 98 and older versions of windows dnt automatcaly detect usb.good luck .
Feb 20, 2009 | Intel Motherboard
Windows 98 SE Driver for Transcend Jet Flash V60 8GB #TS8GJFV60
hi, i srinivas, i am using dual booting of win 98 & windows xp operating systems. when i am using my transcend pendrive in win xp which is easily working, but in win 98, how can we install perpect drivers for my transcend pendrive.
so please give the solution to solve my problem.
Jul 13, 2008 | Electronics - Others
Kingston DTI/512 DataTraveler USB 2.0 not detected when pluugged into USB port on my HP 6910 laptop but works on other HP's and other PC's
This MAY be a problem of the age of your operating system.
For instance, all USB devices have to have the Drivers installed in a Windows 98 and earlier system (because there were no USB devices back then and therefore no drivers were available to be included in the operating system).
Your Operating System may need to have the drivers installed as well, whereas the other computers that you have tried it on may have later operating systems, with preinstalled drivers in their systems, and therefore recognise the USB device and automatically install the drivers when the unit is installed.
Did your unit come with a disk? Then try installing the drivers from that disk and see if this fixes your problem.
If it doesn't, have you tried different USB ports on your computer to see if it is just a problem with the ports?
Good luck
Apr 12, 2008 | Computers & Internet
Microsoft Windows 98 for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
