Question about JVC GR-D244 DV Digital Camcorder
Gr-ds44 cassette door will not close
I had problems with the screen telling me that the tape had the safety on. So I opened it up and the tape was normal to record. When I tried to put it back in the inside door closes but the tape will not go into the recorder. I have put in newly charged batteries but it will not inject the tape. (opposite of eject i think)
jaime
  • 1 more comment
  • Anonymous Feb 20, 2008
    I have a JVC,GR-D244,I can't get the camcorder to take the vidio tape. The door won't close.I can put the tape in and press the top door down "Where it sais push"; But the camcorder don't pull the tape in.It's stuck"I Guess".I don't want to try to force it and do more damage"It sais DO NOT PUSH HERE'' .Can I return it to JVC for repairs?If so What's the address?
    Thanks: George
  • Anonymous Nov 08, 2008
    The cassete door will not close. This happens even when it's hooked up to AV power, so the battery is apparently not the problem. Any suggestions?
  • Anonymous Dec 15, 2008
    My camcorder want take any tape i put into the cassett. and ive only had it for 2 years and i've had no other problems with it intill now. And of course it happens right before Christmas.
I'm having the same problem. According to the manual you should try hooking the camcorder up to AV power to see if the problem is the battery, which is apparently not the problem in my case. Any other troubleshooting suggestions?
Posted on Nov 08, 2008
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
Upon inserting the cassette tape into the GR-DV310, the motor whirs like it is going to close; but then the cassette carrier opens to the extract cassette position. The system does not close and does not...
This is most likely a problem with one of the motor sensors and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 06, 2011 | JVC GR-DVL310 Mini DV Digital Camcorder
Have a JVC GR-D72U video camera. A E03 indicator keeps coming on and it goes into safe mode. What can be done? How can it be fixed?
This problem mostly happen due to defective cassette, by ejecting it, it will solve your problem. If your tape stuck-up inside, apply power, open cassette door, keep it open (around 5 sec) until it opens. and try with another cassette. It must work if not, expert are needed in this case. Good Luck
Aug 30, 2010 | Video Cameras
Video camera appears to record, but nothing plays
Try to run cleaning tape, it may solve your problem.
Nov 21, 2009 | Cameras
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Aug 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Cassette warning
The switch is board monted and is actuated by the loading compartment when it is closed near the rear of the cabinet. It requires an extensive tear down to remove the board before the switch can be replaced. There are other problems that occur also. Does the drum spin up? If so, then the tape is rcognized but its another problem. Good luck, magic seadog
Aug 12, 2007 | JVC (GRAXM18US) Camcorder
JVC GR-D244 DV Digital Camcorder Logo
130 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
