Question about Zanussi TD4212W Electric Dryer
Zanussi TC484W Hi, My tumble dryer has recently started to work intermittently. When you switch it on the timer buzzes away but nothing happens - occasionally if you open door and give it couple of spins by hand it will take off and work fine. I took belt cover off and all looks ok - again - when it is stuck - if I jump start it by turning the wheel it goes away fine... Any ideas
  • 55 Answers
There may be a capacitor in the motor circuit which has shorted out. The capacitor helps the motor start. If the capacitor is shorted, the motor won't start by itself, but will run fine if urged by hand. Good luck.
Posted on Feb 07, 2008
Zanussi TC7102W drying problems
not likely the timer but it does control the heat circuit. suspect the fan-air flow is being blocked and the elements are cycling on a safety thermostat instead of the operating thermostat. check for blocked or restricted vent and plenty of air coming out the vent when running. check for a flapper on the vent not opening or only open part way.
Mar 01, 2012 | Zanussi Dryers
When I turn the start button nothing happens except a buzzing sound...no tumbling happens even if the dryer is empty.
There are two causes for this...bad motor or broken belt... If you are getting a buzzing sound then I would vote for the motor...
Check out a tip that I wrtoe about this...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 31, 2010 | GE DVLR223 Dryers
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Zanussi dryer belt sometimes rotates then stops
is the belt tensioner adjusted corretly? and belt on straight?
Dec 30, 2008 | Frigidaire GLER642A Electric Dryer
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Sep 23, 2007 | Dryers
Zanussi TD4212W Electric Dryer Logo
376 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
