Question about Ovens
GE Spectra electric oven. Oven won't work after using self clean feature.
I just used the self clean feature on my GE Spectra electric oven. Now when I try to turn the oven on the 'clean' light flashes and the oven on light does not come on. If I turn the dial to Clean, the oven on light comes on and the clean light comes on. I have had this oven for several years but this is the first time I have used the self clean.
  • 1 more comment
  • lkbeck01 Feb 06, 2008
    Is there a diagram somewhere that shows where this is?
  • Anonymous Mar 16, 2014
    Used self-clean mode on oven and now oven will not work
  • Anonymous Mar 30, 2014
    the broiler lights but the oven does not, the self cleaning dose not clean.
    Guru:
  • 1,894 Answers
Hello.
Posted on Feb 06, 2008
  • 3 more comments
  • dewan nafees ahmed Feb 06, 2008
    ok You will have to check the wiring connection to the clock and see if there is a loose wire in the clean circuit.
    for that you must get your service manual from someone.
  • dewan nafees ahmed Feb 13, 2008
    wat happened?
  • dewan nafees ahmed Feb 14, 2008
    what happened?
  • dewan nafees ahmed Feb 15, 2008
    this thread is still not closed?
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Need to know how to use the "self cleaning" method for my GE Profile Spectra oven. Also would like to know how to use the convection part of oven also. Thank-you for your help.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Apr 15, 2011 | Ovens
Oven cleaning feature not working on my GE oven
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 05, 2011 | GE Ovens
Hoe do I retrieve the fault code. The self cleaning feature wont get up to temperature
heatman101
Dec 10, 2010 | GE JTP15 Electric Single Oven
What should I use to clean the tough spots in the oven
Use Easy Off only.
Self cleaning leads to malfunctioning parts.
It is a nice feature that does not work well.
May 23, 2010 | GE JKP15 Electric Single Oven
I used the self cleaning feature once on a built in oven. After that it doesn't work. Why?
I used the self clean feature on mine and found out, to late, that it gets so hot that it burns out some of the electrical components. I suggest NEVER use the self clean feature
May 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
I used the self cleaning feature and halfway through got f2 (too hot). we turned off the power and let the oven cool down. now it is making a buzzing noise when the door is closed and the oven is off and...
Sensor inside oven towards the back two screws remove and unplug sensor replace with new one. Sensor burns out when using the self clean feature. New sensor $15-$20
Jan 24, 2010 | GE Profile JTP56 Electric Double Oven
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
548 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
