Question about Kenmore 62802 Electric Dryer
Kenmore 90 Series
I have a Kenmore 90 Series Dryer. It will dry for about 5 minutes and gradually gets louder before shutting off. You can wait about 20 minutes and it will do the same thing. Any suggestions?
Thank you,
Walkin' in wet clothes!
  • tklectro Aug 14, 2008
    I also have the Series 90, and it runs for 5 minutes and turns off. It gets hot, the heater cycles up and down, the rollers are fine, and the thermostats seem to test fine...why would we think that the motor is bad? Is there some sort of heat sensor on the motor?
  • brown703 Mar 25, 2009
    Same prob here in Ohio. Dryer starts normal and runs for 10-15 minutes and shuts off. Starter switch will make a buzzing noise when trying to restart but doesn't seem to be able to turn over.
    After 10 or so minutes it will start normal again and repeat the above.
Dryer will not start
Posted on Jul 18, 2011
I have a kenmore 90 serie electric dryer run fine , but no heat .
Posted on Nov 18, 2008
  • 90 Answers
Bad motor
Posted on Feb 07, 2008
Kenmore king size capacity 90 series
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Jan 06, 2008 | Kenmore 63942 Dryer
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Kenmore 90 Series Dryer started to operate very loudly. The noise sounds like it normally does while drying, just much, much louder than usual.
I would think the belts are getting bad need to be checked anyway, also while your checking the belts check the tenision pulley for the belts make sure it has not fallen off, also, make sure dryer is LEVEL, hope this helps let me know please thks larry
Feb 27, 2010 | Kenmore Dryers
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62802 Electric Dryer Logo
1,466 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
