Lost hard drive
My computer does not see its hard drive (c). why? it has started very recently, it works for some few minutes and then off it goes.
  • wilfredjoni Feb 06, 2008
    currently am in the office. when i get home will try the solution then will tell u 2morow
    Master:
  • 619 Answers
Hi , try restart the computer , if still does not have detection hardrive ,
restart again and it will open starting window setup click del to view setup, set the hardrive to enable.save setting
Posted on Feb 06, 2008
Im Using Windows 8 In Dell Latitude E6520 Core 17 and After I used it for few minutes (3-4 minutes) the system froze. Only the mouse was working. After about 1 minute the mouse cursor stopped responding as...
Sounds like your dealing with a software issue. Most likely a video driver. if there was a recent time that the machine worked, I'd run a system restore. Then look for what might have been installed that caused this problem so you can stay away from it.
May 28, 2014 | Dell Latitude - E5510 Laptop Computer...
Lost install cd software bundle
Hard drives usually self install. Unplug the driver and switch it of so it is disconnected from the USB. restart your computer. turn the power back on for the drive and Plug the USB lead back in to the computer (When started up). Windows should install the driver automatically. This will take about a minute or two.
Jan 26, 2014 | Maxtor OneTouch 4 500GB External USB 2.0...
Cyclic redundancy error with my HDD WD 500gb - used on a Samsung TV32eh54. I kept the HDD plugged into TV for several weeks, Might this be the problem?
Hiii friends,
I too had lost some of my files from WD hard drive recently. So in order to recover data from WD hard drive I used WD Caviar Hard Drive Recovery, which scans entire hard drive within few minutes and retrieves each and every file. You can download it from internet for trial usage.
Dec 25, 2012 | Samsung Computers & Internet
My Western Digital Caviar Black 1.5TB 7200rpm SATA II 64mb cache drive just recently started making noise the past few days. My computer would hang up, precisely when my hard drive decided to wonk out
Sounds to me like your disc controller in the computer (on the motherboard) might be bad. Make sure you check your disk in the device manager.
Since you built this computer did you install the Chipset drivers?
Also look into the Bios at the AHCI setting and change it. I have seen times when changing it made the system accept the drive.
Jun 02, 2012 | Computers & Internet
Blue Screen of Death
yeah unfortunitly you might have to reformat the entire hard drive and start from scratch
May 05, 2010 | Dell Dimension 3000 PC Desktop
Tecra M3 won't boot, hdd light comes on then off.
The hard disk can be installed in another computer, but it won't boot up and run unless the computer is the same make and model with the same devices as the previous computer.
If it is not then you need to do a fresh Windows install to get a working computer.
What you can do as an alternative is to install the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Jul 30, 2009 | Toshiba (K000823110) Motherboard
My Computer does not show hard drive
I'm assuming you use Vista. First view the Maxtor drive (Start - Control Panel - Admin Tools - Computer Management - Disk Management) and see if Active or make it Active. You then can give it a drive letter.
Jun 10, 2009 | Maxtor Hard Drive
" a problem occurred during installation"
here are the drivers for your external hard drive.
try to reinstal drivers and let me know how it goes
http://list.driverguide.com/matches.php?h=932a9713352aa24ea0444960cf489ad2&ids[0]=1119263&ids[1]=1119260&ids[2]=1119267&cid=1256&model=HD160UE5-72 - E5 - 160GB
Apr 09, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Have I lost all my info?
Can you hear the hard drive spinning up ?
if so you can check it using a hard drive diagnostics tool
http://www.tacktech.com/display.cfm?ttid=287#wdc
If its a hardware problem you can try replacing the logic board. You can get one on ebay or you can get one off of another working hard drive (hard drive must be of the same make/model).
Feb 24, 2008 | Western Digital Caviar WD2500BB 250 GB...
Computers & Internet Logo
David Payne
David Payne
