Question about 3M MP 8647 Multimedia Projector
Does the 3M 8647 Projector requires a UPS for proper shutdown
Kindly intimate me that whether the 3M 8647 Projector requries a UPS for proper shutdown. I was informed by someone that the Projector should not be turned off immediately without proper shutdown as it may harm the Projector lamp. If at all it requires UPS for proper shutdown the what's the exact VA to be considered. Should we opt for 500 VA or for 1200 VA UPS.
  • 3 Answers
Look at the amount of va the projector can handle and then decide from there on
Posted on Feb 06, 2008
  • Jimmy Loff Feb 06, 2008
    Firstly you need to check the amount of VA the projector can handle and then it will be much easier to decide.But never just unplug or disconnect your projector it will be damaged.
I have a older overhead projector that I need a bulb for but can't find the right bulb where can I find the bulb at......
You can provide the model # for the projector or possibly look at the actual old bulb to obtain any identification data from the bulb - such as a part #.
Here is a link for 3m replacement lamps:
3M Canada Office 3M Overhead Projector Lamps
Jan 06, 2015 | 3M Office Equipment & Supplies
3M MP8750 lamp
3m mp8750 lamp
usd100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jan 27, 2014 | 3M MP8750 Replacement Projector Lamp -...
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Black dots projected on my 3m scp716 projector
Actually, this is a known issue with this specific model as 3M has acknowledged. We bought 4 of these and 3 have had to be replaced in 3 years because of this exact issue. It requires the mainboard to be replaced and it is almost as expensive to do this as to buy a new unit. 3M has been know help to us on this even through we bought the entire setup (Projector, Arm, Smartboard) and spent over $15000.
Oct 17, 2012 | 3M 78-927719-5 - SCP716 DLP PROJ 2400LUMEN
3M SCP712 projector shuts down after an hour--can't turn back till it cools
Hello
the problem is with overheating. Look whether the cooling fan doesn't work or air filter is cloggy with dust. OK.
Nov 08, 2011 | 3M SCP712 Projector
We have a 3M S20 multimedia projector which is giving off a pink light.
Try replacing input cable or recheck that it's seated properly. (loose/bad cable will produce similar symptoms)
Mar 08, 2011 | 3M S20 Multimedia Projector
This projector turns off while watching. Is this problem with lamp? do i need to replace the bulb?
Do check whether the fan is working properly. The shutdown might be due to overheating of the high intensity bulb. To replace the fan is much cheaper than the bulb. Check it out first before you replace the bulb.
May 20, 2010 | Acer XD1150 DLP Projector
PROJECTOR LOCKED WITH PASSWORD
hmmm...have you connected with 3M on this unit? If it's registered, they will issue you a new password.
www.3m.com
Aug 20, 2008 | 3M MP 8640 Multimedia Projector
3m Pverhead projector not working need help!
Check for corrosion where the bulb sits in. Is there a fuse required. Make sure you handle the buld with cotton gloves (oil from hands not good) Let me know if that works.
Dec 01, 2007 | 3M - EVD Projection Lamp for Overhead...
3M MP 8647 Multimedia Projector Logo
115 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
