Question about Electronics - Others
Mitone 1gb mp3 player
My driver cd got lost and my mp3 is not working. please i need a driver for it urgently.
  • kojobuck Feb 07, 2008
    i have tried but the pc tells me no new driver found. the power does not come and i cant play any music
Hi
I have a problem with my MiTone mp3.My computer doesn't know it when i use it as an usb, because the drivers in the cd doesn't install.please may you give me a solution?thank you!
Posted on Oct 22, 2008
    Scholar:
  • 193 Answers
Ok..if u can play music on it that mean the problem is frome the driver thats true but i think this mp3 player may work without driver it depends wat windows u have and xp sp2 have the driver... ...wen u put the mp3 player in usb port u must get the installing new driver option automaticly and if u get it its a driver problem u must 1st try 2 go 2 google and type dowload (name of ur mp3 player) driver and see wat u can find..if not u can try installing other mp3 player drivers frome ur friends or any usb or mass storage drivers cos it might have the same storage number of ur mp3 player so it might work....
...if u didnt get the found new hardwer option then the problem is or frome ur usb port or frome the mp3 player...if it is from the usb port u must see a question mark in its driver in device manager..if u saw it try reinstalling ur mother board driver cd...if u dont see it format the mp3 player or try changing cable or usb ports....reply and tell me more about it coz this domain is complicated i can help
Posted on Feb 07, 2008
  • 66 Answers
See connect to internet and from my computer check for device manager there you will see in the list of hardware that your unknown device will be listed right click on it and properties from there you update your driver from internet!!hope this solves your problem
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
MP3
I bought a MITONE FLASH MP4 DIGITAL PLAYER. I am downloading files from internet sites in mp3 format but am not managing to listen to them on my Mitone though it seems to be playing them. maybe i dont know how to use it yet. any suggestions please?
Jul 29, 2008 | Sony Write-Once Recordable, 30 spindle...
Software for charging my creative zen v mp3 player
Go to Zen website and look under support for drivers etc
Jul 25, 2008 | Creative Labs Zen V MP3 Player
Lost cd to insignia player 1gb
There shouldn't be any driver software on a CD for this player. If you need the Digital Music Store, go here:
http://rhapsody-usa.com/best-buy/
If your computer is still able to recognize the player, you can still manually place music files on the player by switching the player to File&Folder mode.
Mar 24, 2008 | Insignia NS-DV2G MP3 Player
Philips go gear 1gb mp3 player
plz send driver for GoGear 1gb mp3 player
thanks!!!!!!!!!
manapalekar
Jan 17, 2008 | Philips Sport Personal CD/MP3 Player
MITONE MP3 player software files are formatted
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7  there two different versions of firmware for the assembly player (one can work with bugs)
Methodology firmware:
1. Disable USB cable, turn off player.
2. Holding down "M" connect the USB cable.
3. The menu select 3 - y para (other then USB disk), clicking the right analog stick.
4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory.
5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt).
6. Turn off the player through the safe extraction devices.
Jan 08, 2008 | Yifang Digital Easy Mp3 EM02 MP3 Player
Electronics - Others Logo
429 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
