Question about LG LSC26905TT Side by Side Refrigerator
Freezer works like frig-freezer lite only one working
Freezer works like frig. frig just barly gets cool,lights on door just freezer lite works unplug and plug in works for about 2 hours and then quits working
  • 1949moonlake Feb 06, 2008
    fan in freezer only works after i unplug it and plug it back in this problem began when we had a bad storm and we had a bunch of pwr. outages and elec. would come right back on
  • Anonymous May 03, 2008
    we had the same problem. it was a bad motherboard as well as several other electronic part problems. we also had the leaky ice maker problem as well. it is due to a design flaw which has been corrected. It ended up being cheaper to buy a new fridge then fix my 2 1/2 year old LG that was out of warranty.
    On the LG the fridge actually gets its cold from the freezer so a warm freezer will always give you a warm fridge,
    I have 2 ice maker 1 old design and 1 new design for sale of anyone needs one.
  • 66 Answers
Ch the fan in the frige feel it if is blowing air .or is slow. you need to replace the fan moter.
Posted on Feb 06, 2008
  • sohail anjum Feb 07, 2008
    fan moter or the thrmostste is bad if the fan is not working you need to ck the fan moter. if that is good ck the thrmastate. one or the other is no good
The freezer is working fine but the refrigerator part is warm on the coldest setting and the door has been shut for more than 8 hours.
Hi, I have seen this a lot in my 13 years in maintenance work, the most likely problem is ice build up in back of freezer behind the plastic liner.The drian tub freezes over and when the frig goes into defrost cycle the melted ice has know place to go and covers the air holes that blows into frig to keep it cool. You my have noticed water in the bottom of frig. You will have to either take freezer apart inside and remove ice and thaw out drain tube or unplug frig to thaw it out.
Mar 05, 2011 | Refrigerators
Freezer goes through a cycle and get warm. The ice will start melting and create a mess when the freezer start to cool agian. Temperture in frig and freezer does not hold cool.
Unplug, empty, clean and let set for 24 hours to defrost the cooling coil that is froze solid overwhelming the heater and not letting it work. if the air can't circulate it will not cool. Check door gasket, or tell kids to stop holding the door open as this will cause it to frost up and cause the problem you're having.. Trust me, It works.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer not cooling
sound like side by side check compressor for starting up check defrost timer
May 30, 2009 | Viking DFBB363 Bottom Freezer Refrigerator
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Any thoughts?
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Feb 26, 2008 | Refrigerators
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
LG LSC26905TT Side by Side Refrigerator Logo
178 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
