Photoshop elements 3/Windows XP/failure to save files in Organiser
When I try to save files into Organiser a message appears 'organiser DB AP1 failed to execute properly'..;I have reinstalled twice without effect...please advise
  • Kingele Feb 08, 2008
    I am trying to save TIF files derived from scanning transparencies
    Genius:
  • 3,587 Answers
What type of files are you attempting to save?
Posted on Feb 06, 2008
  • Patrick Michaels
    Patrick Michaels Feb 08, 2008
    ok..so you're on a mac, right? Which OS? With Photoshop and it's transforms, this sort of information can be vital.
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name
Sep 16, 2015 | Adobe Photoshop CS for PC
Sharp Electronic Organiser ZQ-520 repair
please download your manual from here
http://www.usersmanualguide.com/sharp/organizer/zq-520_540
and make sure you have done it correctly.
Jun 23, 2008 | Computers & Internet
Sharp zq 700
Try removing the batteries for a couple minutes and try again. Maybe try different set of batteries.
Dec 29, 2013 | Office Equipment & Supplies
The program will not load , error message not enouph memory
Hold the CTRL key down while this software is starting. This process will prompt you to recover the catalog. If you don't see this pop window then try it again as timing this right will ensure you see the window.
If your catalog cannot be recovered then rename the hidden file psa.prf - This file can located under your user profile folder:
Windows 2000 / Windows XP - C:\Documents and Settings\[username]Application Data\Adobe\Photoshop Elements\3.0\Organizer
Vista or Windows 7 - C:\Users\[username]Application Data\Adobe\Photoshop Elements\3.0\Organizer
Jan 28, 2011 | Adobe Photoshop Elements 3.0 plus Premiere...
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
I have a samsung gt-b3410 and i cant creat an alarm for a birthday
Manage your calendar Learn to change the calendar view and create events. Change the calendar view 1. In Menu mode, select Organiser → Calendar. 2. Select View by → Day or Week. Create an event 1. In Menu mode, select Organiser → Calendar. 2. Select Create → an event type. 3. Enter the details of the event as required and select Save. View events To view events of a specific date, 1. In Menu mode, select Organiser → Calendar. 2. Select a date on the calendar. 3. Select an event to view its details. To view events by event types, 1. In Menu mode, select Organiser → Calendar. 2. Select More → Event list → an event type. 3. Select an event to view its details.
but if u want the thing u specifically asked for http://www.getjar.com/mobile/25220/birthday-reminder-for-samsung-gt-s5233-avila/?s=phones
Jun 15, 2010 | Cell Phones
Using adobe photoshop 8 the editor will import from my Epson Perfection 1260, but the organiser will not get from it displaying "Epson perfection 1260 software for this device could not be launched the...
I don't think it's any of those things. I think it's a Twain Data Source problem. When you install the software for your scanner, make sure you also install the twain data source files. This is the scanning protocol used by all scanners and if not present, the scanner won't import images into Photoshop under the command "File" -> "Acquire."
Mar 25, 2010 | Epson Perfection 1250 Flatbed Scanner
How to set theme in w395
Click menu button.Go to Organiser,here click file manager.In file manager go to themes. Select any theme in this module & set it.
in short MENU - ORGANISER - FILE MANAGER - THEMES - SET.
Feb 23, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
I have the following message and I understand the problem may be with Adobe Photoshop Elements 6 The appplication has failed to start because connAPI.DLL was not found. Re-install may fix the problem
Hi there.
Do one of the following solutions: Solution 1: Remove the NOKIAManager.mox file.
  1. Exit Photoshop Elements.
  2. Open the C:\Program Files\Adobe\Photoshop Elements 6.0\moxplugins folder.
  3. Move the NOKIAManager.mox file to the Recycle Bin, or another location such as your desktop.
  4. Restart your computer.
Note: The NOKIAManager.mox plug-in file is required for Adobe Photo Downloader to download photos from a Nokia mobile phone. If you use a Nokia mobile phone, use Solution 2. If you later decide to use a Nokia mobile phone, either move the NOKIAManager.mox file back to the original location or reinstall Photoshop Elements.
Solution 2: Install or reinstall the Nokia PC Suite software.
Note: Only use this solution if you connect a Nokia mobile phone to your computer.
In order to communicate with a Nokia mobile phone, your computer must have the Nokia PC Suite software installed. Install the software to allow Adobe Photo Downloader to communicate with the phone and download photos from it. If you have previously installed Nokia PC Suite but are still getting this error message, uninstall and reinstall the software or upgrade to a newer version. For more information about Nokia PC Suite, contact Nokia or visit the Nokia web site.
Solution 3: Disable Adobe Photo Downloader.
  1. Open the Organizer in Photoshop Elements.
  2. Choose Edit > Preferences > Camera or Card Reader.
  3. Disable the Auto Launch Adobe Photo Downloader On Device Connect option.
  4. Click OK.
Note: This solution will prevent Adobe Photo Downloader from starting when Windows starts, and it will not appear automatically when you plug in a camera, card reader, flash memory drive, or other memory device. When you plug in one of these devices, and in order to download photos into the Organizer, you will need to start Photoshop Elements and choose File > Get Photos or Videos > From Camera or Card Reader.
Good luck and thanks for using FixYa!!
May 01, 2009 | Adobe Photoshop Elements 6: Windows
I have a Sharp Electronic Organiser ZQ-770 and lack the software to perform the link to my computer (Windows XP). Is it available anywhere please ?
THE ONLY WAY OUT FOR ME WAS TO TOTAL RESET THE ORGANISER. WHAT YOU HAVE TO DO IS PRESS THE POWER BUTTON AND PRESS THE RESET BUTTON ON THE BACK OF THE GADGET. IT WORKS, BUT YOU'LL HAVE TO START OVER AS ALL DATA STORED WOULD BE DELETED.
Feb 19, 2009 | Sharp Personal Organizer & Spanish/English...
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
