Dead power socket
I need a power socket for a hp pavillion ze4200 is there a part number i can quote and where could i get one from i'm in queensland australia
    Scholar:
  • 119 Answers
Directly from the supplies HP all you have to do is give them you model number (ze4200) and they can get the power unit for you or maybe you can try smaller retailers in order to maybe negotiate a good price. thanks
regards
Posted on Feb 06, 2008
HP PAVILLION Dm4 BATTERY NOT CHARGING
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 02, 2012 | HP Pavilion dv6000z Notebook
Can not get my hp pavillion laptop to charge up
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 04, 2012 | HP Computers & Internet
HP Pavillion ze4200 BIOS password, can't boot laptop
Thats a problem..... I think only HP tech support can help. The only thing you can
do is contact them or replace the bios password chip... but then maybe the harddrive
has a password also
Jan 23, 2011 | HP Pavilion ze4200 Notebook
My hp pavilion ze4200 has a broken power jack, as far as I can tell the metal part of the jack is not broken, but rather the backing is snapped and when I tried putting in me power cord it just got pushed...
You might destroy it further. Take it to a CERTIFIED computer repair store expert. You should be able to get it fixed WITH labor for about...$120.00
Nov 27, 2010 | HP Pavilion ze4200 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
I have an HP Pavilion ze4200. It will not even
1. It looks like a battery problem!
2. Plug in your laptop to fully recharge the battery!
3. After 3-6 hours, try to start your system!
4. You can also check by changing the power jack / socket!
5. Is the battery light On / blinking ?
Jan 04, 2010 | HP Pavilion ze4220 Notebook
HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 18, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Does a HP Pavillion T3000 need a fuse? Power cut
It can be the problem voltage variation. The mother board might have some problem. Please check the motherboard for any burnt parts. If there are changing is the only option.
Thanks
Aug 16, 2009 | HP Computers & Internet
Computers & Internet Logo
303 people viewed this question
David Payne
David Payne
