I am trying to connect HPdeskjet F2100 to my computer.i have managed up to 13 but then linked up the usb from the illustration and realised from the reading that i should not have done that. i disconnected , now i find that the computer is not reading the cd rom. My device manager tells me to reconnect but you say not
  • 625 Answers
What does this line mean? (i have managed up to 13 but then linked up the usb ) are you connecting the printer through a hub?
Posted on Feb 06, 2008
HOW TO CONNECT HPDESKJET D2545 PTINTER
The D2545 is a basic USB printer. The USB 2.0 (A-B M/M) cable is not included. The installation steps are 1) plug in the power cord and turn on the printer, 2) make sure that it has paper and ink, 3) connect the USB cable to the back of the printer (the square end) and to the computer (rectangular end) with the computer on. The Windows or Apple OS will then install the basic driver software. If this step does not occur, check if your cable is fully seated. Next try a different USB cable and a different USB port. If you are using a USB hub, try a direct connection to the computer's USB port. If the driver software still doesn't work, check that the correct USB driver is installed and working. In Windows, go to the Device Manager. (Press the Windows Key + X in most versions of the OS or go through the Control Panel under Hardware. That involves left clicking the Start button for Windows 7 and lower. For Windows 8.1 and 10, right click on the Start button.) If you see a triangle with an X or an exclamation point, you have a driver problem. Check the computer manufacturer's site for updated drivers.
Go to http://support.hp.com/us-en/product/HP-Deskjet-D2500-Printer-series/3374272/model/3571289/drivers if you want the full featured software and drivers.
I hope this helps.
Aug 23, 2015 | Office Equipment & Supplies
HP Printer deskjet f2100 driver for win 8
You dont have drivers for Deskjet F2100. You need to connect the printer via USB cable and the printer will be ready to print. To SCan a file, you need to use paintbrush or any other image application tool.
Regards,
Sean
May 29, 2013 | HP PSC 1610 All-In-One InkJet Printer
My hpdeskjet f4140 wont print a microsoft works document
Hi Josh,
Try disconnecting the usb connections to the PC.
Uninstall the printers software and reboot your computer.
Turn off the printer and then on again.
Insert the installations disk into your computer.Follow the installation instructions and connect the printer only when prompted by the installation setup to do so.
Hope this helps.Thanks!
Nov 14, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
HP F2100 Printer
This is due to the USB port "coming alive". There is not an easy way to solve this other than to leave the USB connection unplugged except when he needs to print something. This is supposed to be a power save feature in that the printer turns off when you turn off your computer and turns back on when you are using your computer.
Hope this helps..
Jul 01, 2009 | HP Office Equipment & Supplies
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
Hp psc 1315 printer doesn't scan using my new computer with vista
Try this
Thanks
Riz
Dec 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
Says offline
Hi
Try thiis
Thanks
Riz
Dec 29, 2008 | HP PhotoSmart C3140 All-In-One InkJet...
Can't see scanner
Hi
Try this
Thanks
Riz
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Mar 30, 2008 | Electronics - Others
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
