Light printing issue
Hallo sir,
there was a problem in 4350n mfp printer.the issue is printer is printing fine.but when we print a web page document.than printer printout light.
I have replace the cartridge but issue is same
    Genius:
  • 3,587 Answers
Hmmm..light printing usually comes from the original resolution of the page. Seems that if your printer is printing a core document well, but the web page is light, that means the fonts on the web page are not dense enough for your printer to do it well. My read is that your printer is doing just what it should be
Posted on Feb 06, 2008
How do i Print individual usage report on Hp laserjet M5035 mfp multifunctional Printer.
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print
Feb 21, 2011 | HP LaserJet M5035 MFP Printer
I am having print quality issues on a Dell 2135cn MFP - print on the left side of the page is light.
Try removing the toner cartridge and gently rotating it back and forth. Often the toner will bunch up like a snow drift and where there is little toner you'll have light or no print. If that doesn't do the trick try another toner cartridge.
Feb 18, 2011 | Dell 2135cn All-In-One Laser Printer
How do you find out how many pages were printed on HP LaserJet M2727 MFP
Print out a config report, or a supply status page from the printer. under the reports sub menu. You can also access the embedded web server by typing the ip address into your internet explorer.
Al
Aug 31, 2010 | HP Laserjet M2727nf Multifunction Printer
OUR CM1017 MFP IS HAVING AN ISSUE WITH TONER ON THE PRINTED PAGE: THE LEFT AND RIGHT MARGINS, MAYBE 1 INCH INTO EITHER SIDE IS PRINTING BUT IN A FADED SHADE OF WHAT THE REST IS. CARTRIDGES ARE FINE BUT...
sounds like a imaging drum is getting old. they have a finite lifespan. Especially if the machine is used frequently. Look for an imaging drum replacement. Cheers.
Aug 25, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Can not print on my ricoh 2018
it sounds as if you have an IP address conflict, are you set to Dynamic or Static? if static set the last Octet ie:192.168.0.xxx to something at the top of your ip range, print out a config sheet from the Copier/MFP by going into user tools printer config page and print.
at the bottom r/h side is the host name of the printer typically with Ricoh it will be Rnpxxxx
set the hostname on your tcp/ip port to the host name ensure that you have dns information set on the MFP and your pc and also gateway info on both and that should fix the issue once your reboot the pc and MFP.
if this resolves your issue please rate me accordingly.
Thanks
Aug 06, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Printer only prints source code
Yup ive had customer's come across this issue a number of times try going to mozilla.com and downloading mozilla firefox and then opening a page and try to print and the printout will come out fine its the web software ur using(internet explorer/aol explorer/opera) that is causing this problem.
Please let me know the outcome i may just have another patch for you
Jun 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
Blank sheet after the printout
sir there will be no ink your printer please check and reply again
Jun 03, 2009 | HP LaserJet 4350n Printer
49 2f81- error
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
Feb 17, 2009 | HP LaserJet 4345mfp Printer
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Extra marks on printed pages
1.try stopping the printer halfway thru a print cycle
if you can stop a paper under the print cartridge and before the fuser you can check for print defects on the page before the toner is melted into the paper.
if no defects are found then your fuser may be defective,usually the upper fusers film sleeve tears -testing this way can save you from trying a new cartridge$$$
Apr 16, 2008 | HP LaserJet 4350 Printer
250 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
